Omega Help Area => Omega General Help => Topic started by: addy on 30 August 2008, 17:15:19
I know it has probably been on here somewhere but I am looking to get the timing kit for a 1995 2.5 v6 petrol engine. I have heard different places and names mentioned.
I have been given a price from my local VX parts dept. for £155 inc vat. Is this a good price. The Part No. is 93188674. Does this have the tensioners etc.
I have found this website and they don't recommend FAI or Conti.
http://www.mcc-buyit.com/carparts/brakes/Timing_Belt_Kits.html
While I am asking is there anywhere in Chesterfield Derbyshire that can be recomended to replace the belt and roughly what sort of price am I looking at to have it done?
Sorry for all the questions and if it has been asked somewhere in the forum before just couldn't find it in a search.
look forward to your replies.
Addy
ive used gates kit from vaux centre. price for v6 about £80 and another £30 pump for water pump. has for fitting why not try yourself saves u a fortune. i just done mine and the company who fitted the belt last year were out by a tooth on a couple of the cams. if u do yourself least u know its done correctly. hth :y
Get either Gates or Contitech kit. GM kits made by these 2 suppliers.
Got 2 recently for V6s - Contitechs - top quality items.
Best price i could find was from http://www.buypartsby.co.uk/timing-belt-kit-vauxhall.php?pageNum_Recordset1=17&totalRows_Recordset1=313 - fast delivery, well packaged.
Vx quoted around £150 for belt kit (or £97 + VAT on TC)
Hope that helps.
I got my gates kit from autostuff18 on ebay. it came in at around 70 quid all in. Oh and get the DVD from the OOf shop - superb in helping you save a fortune.
Thank you all for your help. I have looked at both website links given and they are great prices.
https://sslrelay.com/buypartsby.co.uk/timing-belt-kit-info.php?recordID=6714
http://www.vauxcentre.co.uk/index.php?product_id=706112&option=Prod_detail&image_id=365883
are these the ones I am looking at correct?. The second one says that it fits ENG NO 083000419 UP TO 08578511. My engine no is 08091969.
I have ordered the DVD from the shop on how to do the timing belt, will see how difficult it is, I am used to working on simpler carburretor Ford Granadas [smiley=lolk.gif]
To be on the safe side contact whichever supplier you use direct and they will check it for you. hth :y
Hi all
I have watched the timing belt DVD and I feel that I do not have the confidence to have a go at it.
Can anyone therefore recommend a garage that can do it in the Chesterfield, Derbyshire area and how much will it be roughly.
Thank you in advance.
Addy
If you're not doing anything this coming weekend .. join us down at Newent and watch it being done !!!
I'm sure you'll be able to do it then .. :)
Details in the meets section.. :)
The Contitech one (buyparts) is correct for your engine - to ensure you gget right one provide buyparts with your engine nş when you order :y
I think the Gates one may be incorrect for your engine - check out http://www.vauxcentre.co.uk/index.php?product_id=488249&option=Prod_detail - again check with supplier quoting your engine nş.
Thanks to everyone for there help. I have been quoted £117.63 from VauxCentre for the kit and water pump. :y
Thank you Entwood for the invitation to Newent. Unfortunately I have already got plans.
addy
