Omega Help Area => Omega General Help => Topic started by: rikki_essex on 02 September 2008, 14:44:49
i know this is probably not a fault code but the light with the spanner on it just keeps flashing when the brake and accelarator pedal test is done any ideas????
Continuous flashing under that test means no codes stored :y :y :y
HTH
good news, no engine codes stored. Only reads engine ecu. Where you just curious or is something up?
just curious mate i had a crank sensor fault and was wondering if it had gone obviously it has cheers fellas
