		Omega Help Area => Omega General Help => Topic started by: topdogkelv on 05 September 2008, 15:33:07
				hi guys can any one tell me what this warninig is as it came up on my car last night Low beam FLD vision  :'(
				It is a problem with your self levelling headlight system.
 Most likely the link has broken/popped off on the nearside front wishbone.  Have a look behind the front wheel and you should see the link about 4 inches long connecting to the top of the wishbone - thye ball joint at either end may have come off.
				ah that explains things as i lowered the car and disconected it to get at the drop link nut
 prey ive not broken it
				Mine was curiously broken immediately after the MOT test..
				is it important or is it just for towing
				it defaults to the lowest setting, so that you dont blind anyone. But the beam will not be far enough up the road for you to see most likely will fail mot.
				where can i get another one from bud
				vx in the end, i tryed autovaux but they never came back to me. About 50 for the sensor and arm but you can try cleaning and greasing. Fill the sensor  socket with grease and push back on firmly after a good clean to get the crap out. Might be lucky. Myn was breaked tho.as where the rose joints on the con rods, sensor on front/ rear pass side.
