Omega Help Area => Omega General Help => Topic started by: Alex W on 16 September 2008, 10:52:03
As per earlier Cam Cover thread Oil filter cap stuck solid.
Been thinking I might use a hot air paint stripper on the cap in the hope that it might expand a little so I can get it to move?
Would I be wasting my time? Any other considerations?
worth trying when the engine is warm to start with?
Warm engine? Wouldn't that heat up the whole cannister?
I was thinking of doing it when cold so only the cap was warmed up?
hi m8 if u heat the cap this will expand making it even tighter try using a filter wrench on the out side but dont grip too hard cos u will crush the neck of the filler tube
Heat the body not the cap !!! or try sticking some ice on the cap while the engine/filter body is reasonably warm ???
I know a guy who freed a bolt off by spraying it with the stuff you spray on if you get a knock in sport ... some sort of cold spray stuff .. worth a thought ???
Just bouncing ideas .... :(
Yea its for freezing water pipes in central heating systems, so must get pretty cold !
