Omega Help Area => Omega General Help => Topic started by: Vmax on 24 September 2008, 13:22:36
Hello all, is this kit ok http://cgi.ebay.co.uk/VAUXHALL-VECTRA-OMEGA-V6-CAM-TIMING-BELT-KIT_W0QQitemZ250296784684QQcmdZViewItem?hash=item250296784684&_trkparms=72%3A12%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
or should i shell out main stealer price of £144.53??
Thanks. ::) :-/ :y
Assuming its teh right one for your engine then yes, a very good quality kit
Great thanks mark my engine is X25XE 08290450. :)
Whereabouts is engine number to find out if it's the right kit? ::)
and what's the difference Mr DTM?
The number is on your car pass orgive VX a call and quote your reg. :y
The engine number is stamped on the block near the oil filter.
The only change was the cambelt tensioner backing plate
Vmax
I'd check with Mr. autostuff18 that the kit will fit your engine before you make a bid as your engine appears to be outwith the bounds i.e. for a x25e engine the numbers are 08300419--->08578511.
Cheers
MF
Yeah saw that thanks, waiting for a reply :D
That kit have belt and tensioners?
Also allways check the actual block/engine to confirm a number. Ok ringing a Vx dealer on newer cars if you know the history of the car. But older and high mileage cars could have had an engine change. :y
[/highlight]
Good Point!! :y
Yes it is the complete kit - I've had two from this guy already. :y
I bought one from him too about 2 weeks ago it looks fine :y
Engine number is on your V5 registration cert :y or should be !
very good price for a complete Gates kit then :y
