Omega Help Area => Omega General Help => Topic started by: MutantCav on 24 September 2008, 21:35:58
Title: I'm told...
Post by: MutantCav on 24 September 2008, 21:35:58
that wear on the inner edge of the front tyres is most likely the wishbones on their way out?
Title: Re: I'm told...
Post by: unlucky alf on 24 September 2008, 21:39:04
or cheapo tyres.
Post by: MutantCav on 24 September 2008, 21:42:03
How can you check for play in the wishbones and drop links??
Have some brand new still packaged wishbones that came with the elite I just bought need to know if its something thats needed yet...although I guess the imminent MOT will tell me for sure lol
Also how easy is it to change drop links and wishbones?
Post by: Danny on 24 September 2008, 21:51:16
or the camber is in need of adjustment
Post by: MutantCav on 24 September 2008, 21:53:28
Must admit my thought was camber...but be interesting to see if what I'm told can also be true :)
Post by: unlucky alf on 24 September 2008, 21:54:22
if i were you chris id start soaking the bolts with that gear i gave you, ive seen horror stories about the bolts through the bottom balljoint [pinchbolt?], if i remember i`ll bring a tin of the other stuff over, it smells like mothballs but is rather good ;)
Post by: MutantCav on 24 September 2008, 22:11:57
Cheers Tim, might wait till the MOT is done before doing any major work like that but worth being prepared...once the ABS/TC ecu is sorted it should be ready to have a punt and see if owt else needs sorting lol
Post by: tunnie on 24 September 2008, 22:13:11
check for play in the wishbone bushes.... stick a large screw driver between the wishbone and the chassis, and see how much play is in it.
Post by: unlucky alf on 24 September 2008, 22:15:54
major work my `arris!,try mine for size :'( but also CHRIS you get to use your favourite tool :y
