Omega Help Area => Omega General Help => Topic started by: khatton on 29 September 2008, 13:23:09
Title: where can i get this from
Post by: khatton on 29 September 2008, 13:23:09
anyone know where i can get one of the plastic boxes from the top of the engine mine has one blockage i cant clear on it its the one that says ecotec in white on it its a 2.5 v6
  cheers
Title: Re: where can i get this from
Post by: TheBoy on 29 September 2008, 13:27:19
Dealer or breaker.  Doubt you'll get a pattern part
Post by: khatton on 29 September 2008, 13:30:16
tried brakers round here wondered if any one here had one i cant post in the wants section for some reason :y
Post by: markey mark on 29 September 2008, 14:02:54
i might have one will check later :y
Post by: TheBoy on 29 September 2008, 14:04:50
250 posts minimum, as its a combine For Sale and Wanted area, and we've had a bit of trouble in the past.
Post by: The Barge Captain on 29 September 2008, 14:22:04
It will come apart with care using Uncle Stanley, and looks like this inside
(http://i104.photobucket.com/albums/m168/niffler21/DSCF1592-1.jpg)
Mine was blocked solid, but once open cleaned out easy enough, and a bit of araldite or silicone sealant to put back together again.
HTH
Post by: khatton on 29 September 2008, 14:33:26
thanks for having a look to see if you have one and i never thought to take it apart i think it the s bend that must be stuck solid :y
Post by: The Barge Captain on 29 September 2008, 16:26:36
You do get a lot of build-up in the 2 main passages, and the two tiny orrifices easily block.  Carb cleaner is the stuff to use.
Post by: khatton on 29 September 2008, 17:08:13
took it apart like the picture above then found out it was the two little holes bunged up which i could have got to if i had seen them not to worry glued it back together now waiting for it to dry you live and learn :-[ :-
