		Omega Help Area => Omega General Help => Topic started by: manny on 01 October 2008, 21:30:05
				Im going to change brake fluid at the weekend to try and get rid of soft brake peddle.Does the clutch work off the same reservoir or is there another one?
				same one fella !!  :y
				So by bleeding the brakes do i then need to do the clutch?Just for the record where is the bleed nipple for clutch?
No. You don't need to bleed the clutch if you're just doing the brakes.
Sorry. Only ever driven a manual Omega once .... & that was a BMW version!  ;)
				Bleed nipple for clutch is on side of gearbox.
If you want to bleed the clutch the only way is a reverse pressure bleed. Conventional bleed will not remove the air. Probably worth starting out normally just to push the dirt out of the nipple rather than back into the system and reservoir though.
Is it easy to get too?
				Very easy to get to. Just poke your head under the car.
