Omega Help Area => Omega General Help => Topic started by: Martin_1962 on 27 September 2008, 20:47:47
Title: SHock advice
Post by: Martin_1962 on 27 September 2008, 20:47:47
What are KYB Gas-A-Just shocks like?
Mine are soft and bouncy and these look adjustable for towing.
Title: Re: SHock advice
Post by: dieseldean on 27 September 2008, 21:39:50
i recommend monroe adjustables. fitted them to my 1994 mig over 8 year ago when dad owned it and when i get time will swap them over onto my 1998 mig. they come with air pipes leading to a guage and shraeder valve to adjust settings from 1.5 upto 4.5bar which i fitted in the right hand storage cupboard in boot.
Post by: Omegatoy on 27 September 2008, 21:44:47
got the same shcraeder valve and gauge set up in the back of the estate, but they blow up the std air shocks so i can set the ride height to where ever i want regardless of towing the 2 ton caravan or a car transporter trailer, also got lowered  uprated rear irmsher springs as ell as poly rear bushes so when i want to blast it a bit ,just let the air out of the shocks and its noce an low!!! :y
Post by: dieseldean on 27 September 2008, 22:02:28
they last really well and when i check them i let all air out and then check the bounce just to be sure they ok and not just depending on the airbag. run them at 2bar normally 3ish when full of family and their junk  and between 3.5-4 when heavy towing.
Post by: Martin_1962 on 27 September 2008, 22:05:12
Can't find a model number and price for the Monroes - any one have an idea also do the KYBs have the shrader valve?
Post by: Martin_1962 on 01 October 2008, 12:13:56
OK
KYB do not do adjustables
Monroe do the LA361
Cannot find LA361 anywhere.
Does anyone know where to get them from?
Post by: jonathanh on 01 October 2008, 12:18:34
OK
Monroe do the LA361
MVC in coventry may be helpful - sorry haven't got a number but I know they stock KYB and monroe
Post by: Pete Elite on 02 October 2008, 00:06:58
 Hi Martin,
              I'd advise you to stick a banger up your bum hole and light it, That's pretty [size=16]shocking[/size] :D :D :D ;D
Post by: Martin_1962 on 02 October 2008, 12:10:28
Oh well - any other makes of air assisted shocks - none in country and no production planned.
Why is it so difficult just buying a pair of air assisted shocks?
Post by: Marks DTM Calib on 02 October 2008, 12:45:39
QUestion
Are you after adjustable shocks or shocks that maintain a constant level.
e.g. Do you want the Monroe type where you can use an airline to increase or decrease the ride height or the KYB gas-a-just type which self regulate the ride height ?
Or the whole hog of a built in compressor witth sensor etc?
Post by: Martin_1962 on 02 October 2008, 12:57:01
QUestion
That sort - Basically when towing I want to keep the back up better, also just to help counter the weight of my gas tank as well.
The main thing appears to use ride height adjustable shocks IF YOU CAN FIND THEM.
Also they get very confused with adjustable damping shocks
Post by: Marks DTM Calib on 02 October 2008, 13:04:20
Well in reality the KYB gas-a-just will do the same thing without any intervention.
Post by: Marks DTM Calib on 02 October 2008, 13:07:18
High performance shock absorber with monotube high pressure gas construction, designed for high performance vehicles and 4x4s.
For unsurpassed road control
Prevents performance fading
High levels of comfort & safety
Instantly responds to all driving conditions
Reduces tyre and parts wear
Post by: Martin_1962 on 02 October 2008, 13:10:01
How?
What makes it increase the pressure?
Post by: Marks DTM Calib on 02 October 2008, 13:13:57
How?
Once the rear suspension has bounced a few times, it pumps the intrnal gas pocket up......thats the theory anyway.
I knwo somebody on here has fitted some but, I cant recall who it was.
Post by: Martin_1962 on 02 October 2008, 13:16:20
I might give up and get those - and an Eibach spring kit.
Post by: stevief on 02 October 2008, 13:53:17
Monroe Part No 60165 Tee-Valve Kit - Single Fill System (T-Fitting) For GM Air Shocks to Non-Air Leveling Vehicle, For Manual Fill System.
Post by: Martin_1962 on 02 October 2008, 13:54:43
Just given up - now bought some KYB Gas-A-Just
Post by: Martin_1962 on 02 October 2008, 13:55:14
That would have done the job but the car is getting a bit seasick
Post by: Pete Elite on 03 October 2008, 00:41:10
  Hi Martin,
               I found these on eBay but am not sure if they will suit your MY?
      http://cgi.ebay.co.uk/VAUXHALL-OMEGA-SALOON-SHOCK-ABSORBER-KIT-AIR-REAR_W0QQitemZ230232503729QQcmdZViewItem?hash=item230232503729&_trkparms=39%3A1%7C66%3A2%7C65%3A1%7C240%3A1318&_trksid=p3286.c0.m14
