Omega Help Area => Omega General Help => Topic started by: per2003 on 02 October 2008, 15:25:47
Title: omega airbag warning light problem
Post by: per2003 on 02 October 2008, 15:25:47
hi all,
hoping someone can help.
i recently replaced the heater fan in my 2000 Omega, to do this i had to remove the passenger airbag. Since the airbag has been put back i have got the airbag warning light coming on continuosly!
Can anyone advise how to reset this warning light??
thanks
paul
Title: Re: omega airbag warning light problem
Post by: Andy B on 02 October 2008, 15:29:16
You sure that you reconnected it up properly?
A real or 'cheapo TechII' will be able to read & reset the fault code once thereason for it throwing the fault has been corrected.
Where in the country/world are you?  ;)
If you update your profile, there maybe someone just around the corner who can diagnose for you. :y
Post by: per2003 on 02 October 2008, 15:33:56
thanks for the reply.
i will re-check the connection first but i'm sure its ok.
i've updated my profile, i'm in wigan. (new to all this!)
Post by: Andy B on 02 October 2008, 15:36:23
Ah! A Pie Eater!  :y
You have an OOF neighbour & I just visit to work! ;D  :y  :y
And I also have a 'Cheapo Tech II' that is able to clear the fault once fixed.  :y
Post by: per2003 on 02 October 2008, 15:46:33
hi,
dont really understand what you mean by OOF neighbour! sorry.
are you offering to help with my problem with your reader?
How much do you charge for this?
thanks
paul
Post by: Kevin Wood on 02 October 2008, 16:07:15
The airbag system will detect any interruption to related circuits (even with ignition off) and raise a fault. The only way to avoid this is to disconnect the battery before touching it.
I suspect the system now needs to be reset with a Tech 2 or, possibly a cheapo Tech 2.
Post by: per2003 on 02 October 2008, 16:13:09
does anyone know if it will be expensive to take the car to a diagnostics garage to have it reset?
will a normal diagnostics garage have one of these Tech 2 machines?
Post by: chrisdb on 02 October 2008, 17:17:55
This will also happen if you turn on the ignition with the bag unplugged. This happened to me last year and luckliy mu local mechanic reset it with tech 2 for £5...
Post by: Andy B on 02 October 2008, 19:09:44
hi,
There is another Omega Oners Forum member who is also a Pie Eater. ;)  ;)
Of course.  :y
How much do you charge for this?......
Nothing,  :y
Post by: Andy B on 02 October 2008, 19:17:31
Other garages will have generic code readers, Tech II is generally the preserve of main dealers ..... unless you're a forum member with his own ;)  ;D ..... I had an airbag light on my lads Astra F turned off for £30, ut a dealer is likely to charge you more like £50
Post by: per2003 on 02 October 2008, 19:59:19
Andy,
I would really like your help, especially as you have a Tech II reader!!!!!!!
Let me know how you can help. I could come to you or vice versa?
Paul.
Post by: Andy B on 03 October 2008, 18:49:25
Sorted!
One happy customer!
Post by: shyboy on 04 October 2008, 09:41:52
Hope you know what your doing, Andy! :D :D
Post by: per2003 on 04 October 2008, 12:15:28
Thanks Andy,
Very much appreciated!!!!!!!!!!
Paul
Post by: Andy B on 04 October 2008, 13:41:23
I wasn't sat behind the steering wheel ...... just incase!  :y
