Omega Help Area => Omega General Help => Topic started by: ian6pot on 09 October 2008, 00:31:05
Knew it wouldent be long before i needed info :-/
Anybody know the for sure if i can fit the wood effect center dash section in place of my plastic one.
I dont have climate control fitted,it just has the two heat controls for o/s and n/s and blower speed and air direction knob,4 knobs in all.
The only ones i have seen for sale seem to have the bigger holes for the climate controls,did they ever fit them with normal heaters?
only on the very early elites !
but you modify the climate wood trim to fit the dial type have done it myself !! takes a bit of chopping and glueing but worth it in the end ! :y
I've got the wood-effect dash to fit into my car, and will be attempting to swap it in there in the not so distant future.
ive done it as well, i got a spare black plastic one & chopped each control outer out in sections with black plastic still on it, makes it easier to work with, then i carefully cut through the welded plastic in one place & peeled it off but it takes some doing, the wood bit i carefully filed down the lip on the back until it was flush on the back, stuck control outers in with epoxy putty, [a little bit at first to make sure mounting holes lined up] then put it all the way around, you will have to block up the grille bit from the back [black plastic does it] otherwise youll have light shining through, the air circulation button wont fit so cut the lug off the back of it & it goes in, also you have to carefully trim the plastic slides on the back so the wiring plugs will slide in, i think ive covered it all apart from having patience of a saint & hide the swear jar :D :D,,,,best of luck :y :y
It can be done...I have a full wood effect dash here if you need one??
youve seen mine MC & it turned out o,k didnt it??, oh & the bath aint here yet!!!!!
oh & just to add, if anybody has MC`s wood bits & need a spare black unit to chop ive got one floating about ;)
What sort of money are we tailking?
The only person allowed to have my wood bits is Mrs MutantCav lol
PM sent mate :)
Is your spare plastic one a non-climate type, with the rotary control holes? I'm after a replacement for mine which has the old soft-finish peeling syndrome!
