Omega Help Area => Omega General Help => Topic started by: JueV6 on 12 October 2008, 00:30:08
The 96 Elite that i'm breaking has rear door window demister blowers in the doors. Can they be fitted to my 98 mini facelift. :question
No way.. really? where does the ducting run from???or are they plumbed from the outside?
motor is in the door, ducting runs up the door to a vent, switch is where the TC switch in on the MFL the car is Pre-MFL
May have to swap doorcards over, and think the wiring will be missing.
Rear window demisters were fitted to early Elites.
Defo no wiring in door, and i wouldn't think there will be any at switch end either :-/
To the best of my knowledge, early elites with sat-nav (meaning the T/C button had to be moved) had the function plumbed into the windscreen directional blower thingy do-dar electrical wizardry watsit
There is no wiring :( I have been trying to gather the bits together to fit it to mine . Just after the door vards to see whats involved in it .
If you decide not to fit it I may be interested in the bits :y
Carin fitted from MY1998 (option from MY97.5). Very early 1998s have TC switch to left of radio, like all earlier cars. In this case, TC switch was removed, and wiring pushed back when Carin fitted.
Later 1998 and all 1999 had TC switch up in main switch bank. These cars also have the Carin plug, making retrofitting Carin really easy.
I see.
Ialso have all the required gubbins (abit on a scrap car) and was hopeing to retro-fit at some point...
