		Omega Help Area => Omega General Help => Topic started by: Cumbria on 17 October 2008, 20:34:36
				How easy it is to remove the rear prcel shelf. Whats involved in doing it.
				Not too hard, remove 3 bolts from underneath in the middle and some plastic grommit things underneath at the back and the rear pillar cover bits (which is the most awkward bit really) and it comes out...
				Theres a guide here
 http://www.omegaowners.com/forum/YaBB.pl?num=1152745304
 But as Mutantcav says, also remove the ' C ' post trims
 Edit : you will only have the 3 studs and nuts if you have a rear blind, which i dont think you will have on a 99 CDX
				Cheers Timbuk. Thats a great help.
				Theres a guide here
 No studs/nuts on my 2001 CDX just the plastic clips :y
