Omega Help Area => Omega General Help => Topic started by: Don_Semo on 17 October 2008, 12:05:41
Hello everybody. I bought some alloy wheels for my omega but the distance between the bolts on the omega is 110 milimeters and the wheels i have bought the distance between the bolts is 120 milimeters. What you suggest to do to fit the new wheels on the omega???
I have heard of some people use 5 *112 (cause balance problems) instead of 5*110 but 5 * 120 is completely different..
Drilling new holes is necessary :(
ps: better give them back and change with original 5*110 :-/
thanks for the opinion neighbour.
Replace with correct size wheels .. anything else is dangerous.
You wont get them to fit m8 - safely :(
I don't think it'd be possible to make them to fit at all. Wobble bolts - if you chose to fit them - will apparently take a couple of millimeters difference in PCD but I doubt they'd handle 10mm :-/
many moons ago they used to do stud conversion kits but dont know if they have been outlawed for any reason, you could try a search on the net but not sure if they are available anymore.
I know it isn't what you want ot hear, but you can't fit them safely. You should take them back mate.
iv seen stud conversion plates on
www.europerformance.co.uk
*edit- i'v had a nosey and they're 143 quid per pair so 280 quid for all 4!
Wow! :o The price of a set of wheels. :-?
120mm is for older VX/Opels such as Royale's and Monza's :y
thank you all guys. i'll probably sell it to a friend of mine. :'( Sorry for the disturb.
expensive arnt they :P
