Omega Help Area => Omega General Help => Topic started by: yorkshire ripper on 28 September 2008, 17:02:44
Title: rough idle code 0130
Post by: yorkshire ripper on 28 September 2008, 17:02:44
hi guys
car starts fine from cold and warm.
when choke comes off the car runs rough is hunting all over trying to idle, sometimes seems to hold back as if missing. have recentley done HG, cleaned sump,pickup pipe, all breathers, jet in small breather pipe,iacv,throttle body.
then when the EML light comes on it seems to drive ok, idles still lumpy but no hesitation or missing. has had a new cat and front pipe.
please help i need this car to be reliable for work.
thanks
lee
Title: Re: rough idle code 0130
Post by: Ian_D on 28 September 2008, 23:27:30
Check that you have plugged in the o2 sensor on the down pipe!
P0130 fault code is something to do with the o2 sensor I think  :-/
Which you have possibly disturbed when changing the downpipe + cat.
HTH
Ian
Post by: yorkshire ripper on 30 September 2008, 07:54:33
hi
it has all the symptoms of dirty iacv but i cleaned this. how come it drives ok once eml light comes on? dosent want to stall then ? dosent hold back? would the 02 sensor give these probs ?
is it worth replacing the iacv ? suppose it would be a good place to start. how much are they and from where is best to buy ?
thanks
lee
Post by: rickyboy on 30 September 2008, 12:45:18
Is the light on constantly or does it go out at all?  Definitely no holes in the exhaust?  Exhaust is definitely the first place to check.  Take the revs up (slowly) to 4500rpm in 3rd gear and see if the light extinguishes.
Post by: yorkshire ripper on 30 September 2008, 19:52:46
hi
the eml light comes on after a couple of minutes then stays on, but drives fine with it on, drives rough when its not on.
exhaust does seem loud but we checked it on the ramp at work last week and it wasnt blowing anywhere. the cat seemed really noisy, like raspy/tinny noise. kinda gets louder when revved .it is new though, could it be knackered ? should it not make a noise, could this be my prob if its broken up inside ?
lee
Post by: rickyboy on 30 September 2008, 20:05:14
Sounds like the cat if it's making rattly noises.  Would also explain the o2 sensor code.  How old is the exhaust?
Edit...  the exhaust is new!  Cat should not be rattling.
Post by: yorkshire ripper on 02 October 2008, 19:15:56
update...
car still running rough, eml comes on after a few mins and stays on. unplugged afm plug when i got home to see what happened. nothing changed. anyone got any idea's ? gunna do another paperclip test to see if codes have changed.
lee
Post by: rickyboy on 02 October 2008, 21:53:41
update...
lee
Made it difficult for yourself - if you suspected the maf before you'd be looking for a code which was not there.  Now you've unplugged it you will definitely have a maf code so you may replace unnecessarily.
Maf sensors are not a common failure and often a mis-diagnosis from garages.  Unless the maf sensor has been messed about with - i.e back taken off then it's unlikely to be the cause of your problem.
Still reckon you should be looking into the rattle from your exhaust.  Keep checking for more stored codes as well.
Post by: yorkshire ripper on 17 October 2008, 22:33:33
hi guys
right ive been working away and not had time to post...
lets put this to bed ........ ;D
changed maf and car runs mint, at last fingers crossed i have a half reliable miggy.
no water loss,no blocked breathers,no headgasket issue's , no rough idle  :y :y :y :y
YEEEEEEEEEHAAAAAAAAAAA !!!
 i'll polish it now and stick some pics up.
lee
Post by: yorkshire ripper on 24 October 2008, 19:47:34
hahaha here we go again
car started to play up again, can you believe it........ after all ive done for the old girl.
its fixed 100% now..................... i think......lol
changed the 02 sensor and it really does drive nice. 1 week in and no EML or anything going wrong.
lee
Post by: feeutfo on 24 October 2008, 23:36:50
have a butchers
http://www.obd-codes.com/p0130
Post by: feeutfo on 24 October 2008, 23:38:20
have a butchers
Bit late mind...
