		Omega Help Area => Omega General Help => Topic started by: f13platform on 28 October 2008, 16:45:33
				hello i know you  as 2.2 expert if u dont mine .
 i want change the break pad . what style they re ?  i meant they come
 with metal clip or not ?
 and where should i get pair of shock absorber ?
 thank you
				Well i am no expert...
 Firstly this could just be a general posts about brakes.
 All Omegas expect pre 1997 2.0s have the same disc size, 298mm? Pads are the same cross the range.
 How do you mean metal clip? there is one above the pad, which is spring loaded, as the caliper comes down it helps hold the pad secure.
 Shocks? Personally i would get access to trade club card and get them from a Vx dealer.
				Get the brake pads from your local dealer, and at the same time replace the discs.
 Shocks again from your dealer.
 Only fit genuine Vx brake pads and discs.
 thank u for the rpley
 i was in halford and asked for the pad
 the guy was like have u got ur pad with u ?  i was like no
 and then he said  there is 2 type one come with metal clip around it
 and one with out . best to take the pad out and look what they like  :o :o
 i felt he fooling me or something  that s why i asked  :-[
 how much they re with out td card?
 My personal opinion is don't buy discs or pads from Halfords, brakes is one area NOT to penny pinch. They are they only things stopping a 2 ton 80 mph tank of a car.
 Cost from Vx for a set of discs and pads is around £80.
 I noticed a huge difference of the pattern ones they replaced.
				i know what you mean . thank you very much :y
				IIRC Halfrauds do sell Ferodo pads, which are reasonable quality, in addition to own brand. Main thing is to take anything a muppet in there tells you with a pinch of salt. :-X
				pre 97 2.0l ones are 286mm and use a pad with large metal hook.  All other ones are 296mm, and use pads with small spring clips
