Omega Help Area => Omega General Help => Topic started by: max23261 on 29 October 2008, 13:49:03
hi, i have a little rust at the bottom of my drivers door and wondered how hard it would be to fix this as i have never done anything like this before.
if poss for a novice to do what do i need to get started.
max :'(
Not that difficult to do but you must get rid of all the rust or you will be wasting your time & doing it again sooner or later, is it just surface rust?
hi, yes just surface rust 3 small patches at bottom of door.
bit long winded but some good info here
www.carsprays.co.uk/
and AA's guide here
www.omegaowners.com/forum/YaBB.pl?num=1180255700
hi, razzo, thanks for the info.ill give it a try
max :y
Inspect the inside edge of the door carfully as theres a good chance you will find the rust has spread, if so it will also need repairing
ok tony thanks i will . :y
