Omega Help Area => Omega General Help => Topic started by: beemerdevil on 31 October 2008, 17:45:05
Title: Door card removal??
Post by: beemerdevil on 31 October 2008, 17:45:05
hi guys........any possibility of one of you clever people pointing out on the passenger front doorcard, what i need to unscrew/remove to get the card off - would be greatly greatly appreciated  :y :y :y :y :y
Title: Re: Door card removal??
Post by: tunnie on 31 October 2008, 17:47:53
Have a look in the guides section!
Post by: Weds on 31 October 2008, 17:48:55
This one ?
http://www.omegaowners.com/forum/YaBB.pl?num=1152953579
Post by: beemerdevil on 31 October 2008, 17:56:54
blimey.......that was quick !!!!!!!! thanks guys, thats brilliant :y :y
cos what it is, is at the top of the card, where the lock button is, the card seems to have come away from the door, and it rattles slightly - i dont know how this is attached to the door....glued???  clip??? - so i gotta remove to investigate - thanks for your fast response  :y :y :y
Post by: Marks DTM Calib on 31 October 2008, 17:58:00
Glued on.....and can be re-attached with a good glue and some small short self tappers.
Post by: beemerdevil on 31 October 2008, 18:10:39
cheers mark - can i glue it in situ then hold the card hard against door till stuck?? or is it advisable/necessary to remove??
my miggy is running sweet as by the way.... :y :y :y
Post by: Marks DTM Calib on 31 October 2008, 18:23:40
No, I find that the short small screws work best but, they only want to just go into the card of the door card and not miles through it.
There is quite a bit of pressure on the plastic section so the glue does need to be dry before reassembly.
Glad its running well  :y
Post by: Timbuk on 31 October 2008, 18:31:54
Araldite seems to work well but needs a while to set :y
