Omega Help Area => Omega General Help => Topic started by: scooby_doo_do on 31 October 2008, 09:49:44
Title: help me breathe...
Post by: scooby_doo_do on 31 October 2008, 09:49:44
how do I remove the black plastic unit on top of my 96 2.5 v6? I've managed to remove the cover but can't get it off as the pipes/tubes are hiting the scuttle and it won't lift out.
Title: Re: help me breathe...
Post by: Kevin Wood on 31 October 2008, 10:14:39
You might need to remove the throttle body from the front of the plenum as there are a couple of connections that run forwards into the throttle body and these prevent the breather from being lifted straight up.
Post by: scooby_doo_do on 31 October 2008, 16:57:30
so the yank and pull won't work? Bugger.
Post by: Tony H on 31 October 2008, 19:43:42
If you try to pull the breather box off without removing the throttle bodies you could damage the o rings, throttle bodies are only four torx bolts,and throttle cable, Its also a good opportunity to clean them whilst there off only a ten minute job :y
Post by: Marks DTM Calib on 31 October 2008, 19:54:24
As per the maintenance guide  :y
Post by: scooby_doo_do on 31 October 2008, 19:59:41
taken them off, and trying to clean the 4 pipes.. the two centre one's are completly blocked.. Although i can push a coat hanger down one, it still won't unblock...
Tried carb cleaner, wd40 and paint stripper... no joy...
Any suggestions?
Post by: Tafty on 01 November 2008, 09:56:04
Any suggestions?
When I did mine ended up using a stiff single cored speaker cable. But lots of carb cleaner too. I also let it soak in a container - but had access to litres of it from work. Only seen aerosols in Halfrauds.
Post by: Marks DTM Calib on 01 November 2008, 09:57:30
Any suggestions?
Use something small to clear the small breather holes on the outlet part where it enters the plenum (as per the mainenance guide picture)
