Omega Help Area => Omega General Help => Topic started by: Peter H on 07 November 2008, 20:23:15
Title: Changing RH exhust manifold on 2.5 V6
Post by: Peter H on 07 November 2008, 20:23:15
Anything I should be wary of, I have a cracked right hand exhaust manifold and a good 2nd hand replacement.
I presume it is just a case of "soak in penetrating oil, undo nuts and bolts, new gasket, replace the 2 awkward snapped studs (that always happen on thse jobs) and refitting is the reversal of removal".
Yes?
Title: Re: Changing RH exhust manifold on 2.5 V6
Post by: Marks DTM Calib on 07 November 2008, 20:32:34
Yes?
When you say right......drivers or passengers
Post by: Peter H on 07 November 2008, 21:07:02
Off side, right as viewed from sitting in the drivers seat.
Post by: Marks DTM Calib on 07 November 2008, 21:37:05
About 3-4 hours.
Goes something like this
Inlet out, coolant pipes at rear of engine off and out
Coolant bottle out
Air filter housing out
Coolant transfer pipe out
Heat shields off
Front pipe disconnected
Manifold off
Post by: Peter H on 07 November 2008, 21:58:51
In my case:
Cup of tea
Coolant bottle out
Cup of tea
Cup of tea and a biscuit
Lunch
Heat shields off
Cup of tea
Go find plasters
Manifold off
Wife wants me in the house, time to clean up
About 2 days I reckon!
Thanks for the advice, looking forward to completing it if not doing it! :y
Post by: Peter H on 07 November 2008, 22:00:15
Anything special to note about bleeding the cooling system, or just put the heating on full and slowly fill.   I ask because BMW's need a head of water to force the air out.
Post by: markey mark on 08 November 2008, 00:20:53
just fill up with 50/50 mix and squeeze pipes and start and run till fans kick in with cap ON or will chuck water all over ! then check level when cooled a bit  :y
Post by: Peter H on 08 November 2008, 10:43:06
Cool, thanks for that. :)
