Omega Help Area => Omega General Help => Topic started by: downsmen on 11 November 2008, 10:13:16
Hi car wont start it limped to work this morning misfiring
i have got the following errors
10 1 1 5
10 3 2 5 i know this is Knock Sensor
10 1 2 10
10 4 10 3
10 1 3 10
10 5 10 5?
10 3 4 10
I have checked all the connections and they seem to be all connected apart from the Knock Sensor as i am not sure where it should plug back into
also how do you clear the fault codes from the ecu
Forget all the codes apart 10 3 4 10 which is the cam sensor. Changing it or even cleaning it should get rid of the codes. First step is to take off the fan belt and the spark plug (ecotec) strip. Remove the timing belt cover and then remove the plug for the sensor and then the sensor itself which is located in between the camshaft sprockets.
Try giving the sensor and its mating face a good clean then fit back together. Drive the car and get the revs above 4500rpm and the light should go out. If not replace the sensor and only with a genuine vauxhall part.
