Omega Help Area => Omega General Help => Topic started by: max23261 on 14 October 2008, 20:44:20
Title: remote fob
Post by: max23261 on 14 October 2008, 20:44:20
hi guys, my remote fob doesnt want to work ok to open the car but will not close.put new batteries in but still the same.where can i get a new one and do i need to have it programmed.
max
Title: Re: remote fob
Post by: Martin_1962 on 14 October 2008, 20:47:00
Does the light work?
If not it needs new switches - PM me
Post by: max23261 on 14 October 2008, 20:49:00
hi, yes the light works
Post by: Martin_1962 on 14 October 2008, 21:39:37
If it works on all buttons no idea, if the light work with the working functions but not the non working - it is switches
Post by: TheBoy on 14 October 2008, 21:40:33
I would still say switches...
Post by: dbug on 15 October 2008, 08:50:55
Try syncing it
Post by: laurie on 17 October 2008, 18:24:13
how do you synch it?
Post by: dbug on 17 October 2008, 19:01:42
Put key in ignition and switch on ignition; system will then remain
in synchronizing mode for 30 seconds.
Briefly press either of the buttons on the remote control unit while the key is in the ignition.
The central locking system should lock and unlock to show that the remote control has been synchronized.
If it does that should then work ok. :y
Post by: max23261 on 20 October 2008, 15:27:06
hi guys, thanks for all your help remote works ok now.
max  :y
Post by: Nathv6 on 20 October 2008, 17:29:05
i have simalar prob with mine and been to vx n they want 60 plus vat for new key fob and to re program just wandering if there is a cheaper alternative or where i could possibly get a fob ????
Post by: TheBoy on 20 October 2008, 18:59:52
Buy a (correct!!) fob from egay, then come see me, M DTM or Kevin Wood ;)
Post by: dbug on 20 October 2008, 19:01:45
max  :y
Wot was the cure? Resyncing?  Helps other members to know result :y
Post by: max23261 on 21 October 2008, 18:10:00
www.remotekey.co.uk/cars/vauxhall/vectra-omega-3.
i came accross this web site and seems to be the cheapest around. as for solving my problem i resynchcronised the fob while sitting in the car just turn on ignition and press fob. doors will lock press again and they should open.now you should be synchcronised
thanks again for your help.
max :y
Post by: dbug on 21 October 2008, 19:27:02
 :y :y
Post by: kevin61 on 12 November 2008, 20:19:14
Think I've got myself the wrong one (Delphi 433.92Mhz instead of Kiekert 433Mhz).  I take it they are not interchangeable.  Silly question, I know, but has to be asked now I've bought the damned thing.
Is an easy way to spot the difference that one has an LED and the other doesn't?
