Omega Help Area => Omega General Help => Topic started by: bighed on 12 November 2008, 20:48:29
Title: How much coolant
Post by: bighed on 12 November 2008, 20:48:29
Am changing hbv while engine is in bits changing coil pack. How much coolant do I need. Did a change about 4 months ago but memory like a sive n all that, also how much is vx coolant and its 1 litre bottles it comes in isnt it? :y
Title: Re: How much coolant
Post by: Andy B on 12 November 2008, 20:58:57
You need 5 litres for a 50:50 mix, whole system is a bit over 10 & if you just drain via the rad drain tap you won't get much more tha 5 out anyway. My local dealer only stocks 1 litre bottles too, but will get you a 5 litre if you ask. I don't think there's much difference in price anyway between 5 x 1 litre & 1 x 5 litre bottle.
If you're just doing a HBV you're not going to loose too much. I did mine again earlier in the 'summer' and just drianed a litre of coolant off & put a bottle of antifreeze in.
Post by: bighed on 12 November 2008, 21:10:49
Thanks. Is there anyway of changing 100% of the old coolant???
My mate who has a V6 vectra says his mechanic pulled a pipe off coolant bottle and started engine. This started pumping old coolant out this certain pipe, as he was pouring in clean water in via a watering can. Once water in engine is fully clear he poured in water/coolant via another watering can till right mix was reached???  :-/ That sound right???
Post by: Marks DTM Calib on 12 November 2008, 21:15:19
Nope as the cold water will stop the stat opening.
Post by: Andy B on 12 November 2008, 21:16:18
You can do I suppose, but not worth the effort IMHO. You can remove the water pump if you want, that'll drop most, but hard work. If you drain via the drain tap and dilute by half a few times, you'll have the vast majority of the original coolant out.
Post by: bighed on 12 November 2008, 21:36:12
My problem is when I bought omega it still had the old blue vx coolant in it. I got most of it out and put in the new vx orange coolant. The two have mixed and i have been left with a sh1tty greeny colour coolant.
Post by: Andy B on 12 November 2008, 21:43:13
You needed to drain & fill it a couple more times .... but you don't need us to tell you that. ;) :y :y :y
Post by: bighed on 12 November 2008, 22:40:35
so... it wont do any damage mixing the blue and orange  :-/
Post by: Andy B on 12 November 2008, 22:42:32
Errrr? Not sure. :-/  I don't think so. :-/ :-/
Post by: ngrainqey on 12 November 2008, 22:45:21
lol the different colours are just for different temp ranges - depending on colour it needs diluting more or less if that makes sense
i fancy a funny bogey coloured coolant tbh :P
for novelty value only i might add haha!
Post by: bighed on 13 November 2008, 10:12:03
It looks terrible tbh.  :'(
Post by: Elite Pete on 13 November 2008, 12:44:51
I thought the different colours were to distinguish between longlife 5yr pinky orange and the shorter life stuff, Bluey Green 2 year stuff
