Omega Help Area => Omega General Help => Topic started by: X30XE on 11 November 2008, 21:04:44
Title: 2.0 GLS Auto - Immobiliser 1502 - No signal
Post by: X30XE on 11 November 2008, 21:04:44
Hi,
Just bought a 2.0 gls auto on an S plate as a temporary car.  Earlier today the gearbox went into fault mode, and would only run in 3rd gear.  When I got home I parked up and turned the engine off. Now the car wont start up, fault code coming back as 1502 Immobiliser - No signal.  Any common culprits for this, or is it a case of call the scrap man?
Title: Re: 2.0 GLS Auto - Immobiliser 1502 - No signal
Post by: Entwood on 11 November 2008, 21:07:36
Check inside the key that the little black square thing has not moved from its alloted place ...   I had that on the old beast and it wouldn't start !!  Seems the transducer chip must be in the "right" place for the reader chip by the keyslot to register it ...
HTH
Post by: ngrainqey on 11 November 2008, 21:09:42
might be a connector thats come loose or could be that you need to resync the immobiliser
does anybody know why the immobiliser re-arms its self btw after around 15 seconds?
very annoying having to repeatedly blip it each time i get out of the car to play with the inlet then try cranking it again
btw it's with the key in ignition...
somebody will be along shortly i imagine about your immobiliser, might have to buy the ecu and stuff off somebody to sort it out
Post by: X30XE on 11 November 2008, 21:12:55
HTH
I'll have a look, but I think it unlikely that both keys have gone fubar in the same day.  Think it more likely the car end?  :-/
Post by: X30XE on 11 November 2008, 21:15:56
How easy is resyncing the immob?
If it's not just a matter of fixing a dodgy connection it'll be weighed in.  It's not worth the hassle for a ropey 2.0 gls im afraid.   :(
Post by: ngrainqey on 11 November 2008, 21:21:48
urm on the infra red keyfobs you need to have the key in the ignition then blip the fob at the black dome and the light should flash (think thats how you resync) and with the rf ones it's easier (there's a how 2 in general maintenance maybe on how to do it-similar to the ir one)
Post by: X30XE on 11 November 2008, 22:00:47
Thinking about it, would the code not be "1501 - No or Wrong coding" if  the keys weren't sync'd?
Post by: ngrainqey on 11 November 2008, 22:08:49
sometimes comes up as random faults to do with the immobiliser-dont think it knows what it's doing its self sometimes tbh haha!
if you need then iv got a transponder and stuff off my 2.0 can let you have it for literally next to nothing plus a 3.0 ecu set as they've got mixed up haha! ;)
Post by: MutantCav on 11 November 2008, 22:15:26
To resynch...key in position 2 and press the door lock/unlock button, when it resynchs should lock/unlock the central locking...pretty much instant...
Post by: X30XE on 11 November 2008, 22:26:16
Ok, just managed to resync key 2. It now unlocks the CL on the plip, where it didnt before. Neither key is starting the car tho.  Also, noticed the rev counter is dancing about like a nutter while ign on pos 2??   :-?
Post by: X30XE on 11 November 2008, 23:06:02
From an old post here...
"Re: Bypassing immobiliser
Reply #6 - Sep 24th, 2006, 9:14am
If selector switch is knackered (ie it thinks its in a drive gear, then it won't even turn over..."
Given that I suspect the selector switch could be fubarred (due to limp mode activation), is this on the same circuit as the immobiliser?
Post by: unlucky alf on 11 November 2008, 23:13:17
im not sure if its on the immobiliser circuit but it does sound like the selector switch as you say, might be worth dropping it down for a look & perhaps a clean out, check the white nylon bit isnt cracked as ive seen it on here before where a crack has caused issues,,,good luck :y
Post by: X30XE on 11 November 2008, 23:37:08
Ok, il have a look tomorrow. Is the switch accessed from inside or underneath?
Post by: unlucky alf on 12 November 2008, 00:13:29
underneath, 2 x 10mm bolts & the big nut in the middle which i think is 15 mm, the switch unplugs, if you follow the wires youll find it, should be clipped to the g/box :y
Post by: X30XE on 12 November 2008, 22:46:49
Yep, 2 x 10mm bolts (one of which conveniently hidden from sight and a right .... to get at, and a 16mm in the middle.
Removed the switch, opened up. There was some evidence of moisture inside so i have mopped it up along with what I pressume is white lithium grease?  Have put the lid back on and located back on gearbox with one bolt in just to test, unfortunately all the lights still come on when in P, 2nd or 1st.  Might try a more thorough inspection/clean of the wiper/tracks in the switch tomorrow, and get some lithium grease as well.
Could really do with knowing whether the immobiliser issue is related or a seperate fault.  Does anyone know for sure?   :-/
Alternatively does anyone know which wires/tracks to short to get the ecu to acknowledge "park" position?
Post by: unlucky alf on 12 November 2008, 23:33:33
couldnt tell you for sure as there is other things that may cause it, anyhow you say all the lights are coming on by the gear stick, was it doing this before?, the switch is adjustable so mght be an idea to get both 10mm bolts in & move the switch about & see if you can get the lights to function properly as it is adjustable, ive had the same problem when i first fitted my g/box & it was just adjustment so hopefully youll be o,k,,,,best of luck :y
Post by: X30XE on 13 November 2008, 20:42:38
Still having no joy with this problem.  In key position two the fuel pump relay and injector relay can be heard rattling away to themselves, but when key turned to 3 - nothing.  Fault code is still logged as 1502 only.  But EML doesn't always flash after failed start like before, so could the stored 1502 code be no longer relavent?  :-/
Beginning to doubt gearbox connected to immobiliser issue.  No better in Neutral for starting (which appears to select ok, and says should start with in handbook).
