Omega Help Area => Omega General Help => Topic started by: bighed on 17 November 2008, 18:29:23
Title: Climate bulbs
Post by: bighed on 17 November 2008, 18:29:23
Hi guys. I thimk i remember reading somewhere (possibly how 2??) that there are only 5 bulbs in the climate control panel. Well on mine the following are and are not working.
ARE WORKING
+ & - on left side temp up and down, auto/off/fan up and down, and temp set (18,19,high etc) on the right.
ARE NOT WORKING
Temp set left, fan speed number, Fan position (onto window, down onto feet etc) and + & - on right hand side.
So is there another problem apart from bulbs there then as I make that 7???  :-/ :y
Title: Re: Climate bulbs
Post by: TheBoy on 17 November 2008, 18:48:31
There are 5. Just accept that ;D
Each LCD has its own backlight (so thats 3 bulbs), all the backlighting of the buttons are done with 2 bulbs via lightguides.
The Auto and the direction amber LEDs are LEDs and cannot be changed. Fortunately, they never fail
Post by: bighed on 17 November 2008, 18:51:54
Ok thanks. Thats next job, along with new crank sensor, oil, filter, coolant change, New drivers wing, exhaust manifold blow, two new tires................. ;D :y
Post by: Darth Loo-knee on 17 November 2008, 20:47:50
Jaime is right mate, I went to Vx and they looked at their computer and told me there were 4 bulbs, after I had been told probably by TB actually that there were 5.... turns out there program or whatever has a mistake on it :-?
Change all 5 while you have the panel off  :y
Post by: Welung666 on 17 November 2008, 21:03:52
Just done mine... had no button lights and drivers side temp display was out. Basically 3 LCD's have own bule and left and right side are run by 2 bulbs :y
Post by: Lazydocker on 17 November 2008, 21:08:19
There are 5... Changed all of mine in March but had one go last week >:( >:( >:( >:(
Post by: bighed on 17 November 2008, 21:38:17
do u know what these bulbs are called please  :-/
Post by: Welung666 on 17 November 2008, 21:46:54
There are Vx part numbers on the howto :y
