Omega Help Area => Omega General Help => Topic started by: MG on 18 November 2008, 09:49:48
Hi,
I have a 1999 V6 Elite and just recently the Central Door Locking has developed a fault. When I lock the car using the key-fob or using key in lock, the car unlocks itself about 10 seconds later!!
Sometimes when I park up and close the doors, before I have a chance to lock the car, she decides to lock herself!!!
Has anyone else had this problem??
Does anyone have a fix for me please.
Many thanks,
Mel.
check your wiring going into the drivers door, make sure the plug is o.k & dry, then check the wires that go to the plug for any cuts etc as they can get broken due to the door opening & closing. ;)
Likely to be a lazy motor or the mechanisms need a good lubricating, door card off job. :y
Thanks Andy and Tim.
Will take a look over the weekend and let you know what I find.
Cheers,
Mel.
sticky soleniod matey ! try lubeing it if that dont work will need replaceing have a few spares available if you need one ! :y
Cheers Markey Mark will give it a shot of lube!! Any particular type ??
not wd40 ! duck oil or simaler :y
read this, and watch the video...
http://www.omegaowners.com/forum/YaBB.pl?num=1175610013
This is your favourite post isn't Tunnie ;D :y :y
