Omega Help Area => Omega General Help => Topic started by: Greg2041 on 18 November 2008, 09:06:22
Title: Drivers Door Mirror Replacement - HELP!!!!
Post by: Greg2041 on 18 November 2008, 09:06:22
Yesterday eve, a mad driver swerved, hit my mirror at about 40mph and didn't stop!
It has badly broken damaged the whole of the mirror cluster and will need to be totally replaced.
How easy is it to replace the unit and how much should I pay?
Yours hacked off.....
Greg
Title: Re: Drivers Door Mirror Replacement - HELP!!!!
Post by: Andy B on 18 November 2008, 09:13:45
Greg
A quick look on eBay clicky (http://shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fCarsPartsQ5fVehiclesQ5fCarPartsQ5fSM?_nkw=door+mirror+omega&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=drive+belt+omega&_osacat=0)  suggests around £15/£20
Gently prise the tweater speaker from the top of the door and they're held in by three 4mm screws. I can't remember now whether I also removed the top corner of the door trim too when I last removed mine ...  :-/
Post by: VXL V6 on 18 November 2008, 09:30:10
I had to do the same on mine, on the facelift you can just release the door card on the left and using a right angled screwdriver you can get to the two lower screws without removing the doorcard.
Note, if you have an elite you will need the mirror from an elite as it has a return feed to the seat for the preset positioning function.
Post by: MutantCav on 18 November 2008, 09:36:41
On a 99 Omega...remove the tweeter, it prises out towards the rear gently...remove the door handle part of the door card 3 screws (be very careful taking the rubber bit of the door handle off, a small thin screwdriver angled under the top slightly downwards to gently unclip it, the lug inside breaks very easily!!)...then you have access to the 3 screws that hold the mirror in place...
What colour is the car as I assume the wing mirror is colour coded?? Easiest to get a second hand replacement in the same colour :)
Post by: Greg2041 on 18 November 2008, 10:13:19
Thanks for the info.  Mine is a dark blue metallic one.  Not sure what the correct code is.
Sounds like this is going to be a bit of nightmare.  I'm just wondering whether I can swop any of my Elite bits over with a non-Elite mirror?
The motor still seems to work but there ain't a lot of plastic left!
Greg
Post by: Greg2041 on 18 November 2008, 10:18:51
Meant to add mine is the older model (1998)
Post by: Andy B on 18 November 2008, 10:20:47
Greg
I can't see any reason why you'd have any problems doing so
Post by: Greg2041 on 18 November 2008, 10:35:37
Another project I guess. What a pain!
Greg
Post by: VXL V6 on 18 November 2008, 19:53:17
Greg
Yes you can, you need the motor unit and the loom, to extract the loom you need to remove the pins from the connector block at the motor end to pull the loom through the mirror housing.
I then just cut the loom on the new mirror at the door fixing end and taped the elite loom to it and pulled it through.
The plug is wired:-
Pin 1 - Grey / Green trace
Pin 2 - Black / Red trace
Pin 3 - Red
Pin 4 - Green
Pin 5 - Grey
Pin 6 - Yellow
Pin 7 - Black / Brown Trace
Pin 8 - No connection
NB. The plug has odd no's on one side and even on the other.
Hope that Helps
Post by: Marks DTM Calib on 18 November 2008, 20:02:47
Kin ell...... a few screws a bit of trim and an electrical plug....they dont come any easier or qucker than that
Post by: ngrainqey on 18 November 2008, 20:42:18
...what mark said, piece of pi$$
prise the tweeter off which is a piece of pi$$ then undo the three screws and also two 10mm bolts then yank the mirror unitoff and unplug the connector and swap for your new/second hand mirror unit!
then the famous line (refitting is reverse of removal)
