Omega Help Area => Omega General Help => Topic started by: mustangboy on 20 November 2008, 16:36:46
Title: Omega 2.5 TD power steering belt tentioner
Post by: mustangboy on 20 November 2008, 16:36:46
can any one advise me off the possable cause of my power steering/alternator belt suddenly losing its tention.  what type of tentioner is it ? spring loaded or manually tightened. its very slack so slack the power steering is very jumpy.  was ok yesterday :-( .  just need a bit of helpful info from any one who has had same problem before i tackle the job at the weekend.
regards to all chris
Title: Re: Omega 2.5 TD power steering belt tentioner
Post by: TheBoy on 20 November 2008, 18:54:26
right, don't use it, as waterpump is aux belt driven.
Spring loader tensioner, so either the arms have snapped, or its seized.  Should be obvious once you've stripped enough to visually check.
Post by: mustangboy on 20 November 2008, 19:09:46
thanks for that info will leave it alone till i get  chance to check it out at weekend
Post by: TheBoy on 20 November 2008, 19:13:53
check all pulleys are free, in case one seized, breaking tensioner.  worth checking vanes still in tact on waterpump as well....
Post by: mustangboy on 20 November 2008, 19:14:21
are they easy to free up if zeized ?
Post by: TheBoy on 20 November 2008, 19:39:46
they can seized on pivot point. depends how much damage is done in freeing off
Post by: mustangboy on 20 November 2008, 19:50:40
ok. may price up a new one before i start messing with it
Post by: TheBoy on 20 November 2008, 19:56:30
Bet not cheap new, but no harm in asking. Might be worth trying beemer and Landrover dealers as well.  But 2nd hand may be more cost effective.
Sadly, the one in the garage is fubar, so no good to you ;D
Post by: Omegatoy on 20 November 2008, 22:28:40
SEEN THE TENSIONER GO OVER CENTRE COS OF WORN BELT ,
may be as simple as that!! it wasnt only the belt tho the tensioner itself had very worn nylon bushes too, !! :y
