Omega Help Area => Omega General Help => Topic started by: frank1 on 07 November 2008, 22:38:36
does anyone no what mpg a 2.5 td shud be doing round town because mines doin no better than 29mpg, i may aswell be runing a 2.5 petrol! also how much better on fuel are they when chipped?
varies car to car. i've yet to chip mine but people who have seem to get better figures. my old 1994td used to do 45ish on work run, its replacement 1998td only manages 33ish on same run. currently only getting 26ish but it is a bit poorly with engine light on :-[
Around 47-50mpg+ when chipped (although again thats based on Tim's 94 TD)..not sure if thats just around town though, probably combination plus much better torque and acceleration but you need an AR35 gearbox or its bye bye AR25 in 30 seconds flat if you have an auto! :)
Got 2 decent AR35 gearboxes here if interested (£150 delivered to you next day)
mines a manual thanks
Good stuff I *think* the manual box can cope (although cant see what the difference is as its still only 250Nm Torque max like the AR25) but I believe its ok with manual...although I also have an R28 3.0 box/clutch etc if anyone knows different! :)
Mine gives 33 mpg on average
The best I ever got on a long run was 36
This is by calculation not a MID
as MC says according to my display im getting 47.5,[how accurate?] ive never bothered to try & work it out as youve then got to question the accuracy of the fuel gauge!, either way ive noticed slightly better economy as well as much better performance so im happy :y :y
the tractor, esp auto, not brilliant mpg wise around town (non of omegas are). 1.7t takes a lot of energy to keep getting from 0 to 30
I reckon you should be looking at 32/34mpg around town driving, and over 42mpg easily on more longer motorway type journeys.
After having mine chipped I am going to do a proper check to see how accurate the MID display is, I don't think it's telling me an very accurate reading.
It's hard to believe I am doing 37mpg towing a 1460kg caravan with the beast, especially when I was only achieving around 26mpg pre chip. I think it's returning now more like 31mpg towing, which is excellent given the combination 3 tonne +
Mick
Mick
I wish!!
MIDs tell lies!!
Mick
I wish!!
MIDs tell lies!!
The MID tells what the engine ECU thinks its using, which should be reasonably accurate, seeing as ECU gets feedback from cylinder 4.
Running locally mine's in the mid-30's. That's pretty good, considering the tough terrain in the Valleys, plus a kerbweight of around 1.7 tonnes.
On long runs, it easily achieves the low 40's per gallon.
Since the lads here chipped it, she's positively 'singing' in the mid 80's.
Improvement in fuel economy too ... !
if my tractor is ever cured and not keep shining the eml at me then it will definately get chipped as it needs all the help it can get to make the x25td to run as smooth and economically as my old u25td
Keep us posted Dean, (on that No.4 injector), that is!
thanks mate you just reminded me to update my dying tractor thread :y
Just given the tractor a fair thrashing on a near-200 mile motorway run.
Tank filled to the brim, then straight on to the motorway. Refilled to the brim after coming off the motorway, did the calculations - the tractor returned 33mpg.
Not bad really, considering it was positively cruising around the 75-80 mph mark for the whole journey.
There you have it chaps ..... !
Hmmm, I would have expected significantly better :-/
That's what I get in similar circumstances too
I get similar mpg day to day (shitty stop/start commute), and, judging by the smell, I'm still pissing diesel out everywhere :-/
I have been calculating MPG from my last 5 tanks of Tesco Homebrew and the worst I have achieved (30 mile a day commute, 28 miles of which is dual carriageway) is 34mpg.
On a 300 mile run down to the south coast and back last weekend I managed to get 47mpg, using almost bang on half a tank (although the latter part of the tank seems to go much faster!)
This is with a chipped, smoky TD with 180k on the clock.
Mines un-chipped, automatic AR25 with 144K on clock & was once full of flood water!
have you chrcked return pipe to tank yet?
Filled to the brim again, and ran it locally for a few days.
Guess what? ........ 33mpg running locally ...... !
There is a vent pipe that may be suspect, also, some signs of a (histroic ?) leak on top of tank - needs a second opinion on that.
Not convinced about a couple of the (new) bleed off pipes either.
I get 34 normal . 34 cruising at 75-80. And 31 towing 1600kg boat preston to holyhead at 60, slower up the grades.
Never went over 96C new rad no viscous.
It use to go to 100 on grades, not towing.
