Omega Help Area => Omega General Help => Topic started by: dieseldean on 22 November 2008, 13:20:43
Title: locking a tractors flywheel
Post by: dieseldean on 22 November 2008, 13:20:43
what is correct way to lock the flywheel on x25td. there is two ruuber bung revealing oval shaped inspection holes in the bellhousing, is this a point to lock the engine. the engine needs locking to remove and exchange fuel pump and to help time the pump when fitted.
Title: Re: locking a tractors flywheel
Post by: Seth on 22 November 2008, 16:10:11
According to the info I've been given, the flywheel is locked at No.1 piston TDC on compression stroke to remove the pump.
The locking-pin is inserted through a hole located on the nearside of the engine. The hole is in-board of the bottom-most cylinder-block-to-bellhousing bolt.
When the pump is removed, the woodruff keyway will then point upwards.
Post by: dieseldean on 22 November 2008, 16:13:03
SORTED :) :) :)
if anyone has to do this then look on engine side of bellhousing near to starter motor. there is a little rubber bung with a pulling tab that is hiding between 2 fins pull it out and there is the hole to lock the flywheel. take of oil filling cap and you can just see the 1st cam lobe turn engine until the camlobe is just past 12 o clock (cylinder no1 is now 90degrees btdc) and about that point a 8mm drill bit will lock the flywheel from the above mentioned hole. ;)
Post by: Seth on 22 November 2008, 16:32:44
Good stuff Dean,
Glad you sussed it ...... !
It seems that the whole set-up on these engines is fixed around the No.1 TDC mark.
Some diesels that I've worked on have seperate 'INJ' and 'TDC' marks/locking holes. Obviously then, the 'INJ' mark is ahead of the 'TDC' mark by a few degrees.
Keep us posted!
Post by: dieseldean on 22 November 2008, 16:39:29
pump is now swapped :) daylight is beating me now so tools thrown in drivers footwell and just hope the rain or snow keeps away tommorrow when i put the rest of the jigsaw back together.
Post by: Seth on 22 November 2008, 17:10:32
Good luck for tomorrow Dean!
Lets hope everything turns out well - 'fingers crossed' for you mate!
Post by: TheBoy on 23 November 2008, 10:54:43
Sorry didn't see this earlier. I have a TD locking kit here.
Post by: dieseldean on 23 November 2008, 11:18:43
new pump fitted but wont start. runs for about 2seconds then stops. hvn't put inlet manifold or rad and water hoses back yet but will usually run without inlet manifold even though no help from turbo.
cracked of injectors and they spit fuel ok when turning over.
Post by: Andy B on 23 November 2008, 11:23:43
new pump fitted but wont start.  .....
You're not having much look with this car are you Dean!  :(  ;)
Post by: Omegatoy on 23 November 2008, 14:30:11
eek just replied to other p[ost didnt see this one!!! if it runs for couple seconds then got to be a simple answer, fuel or maybe the temp sensor sensing no coolant and switching off?? :y
