Omega Help Area => Omega General Help => Topic started by: husam on 26 November 2008, 09:48:26
Title: where?
Post by: husam on 26 November 2008, 09:48:26
I have been informed to buy the complete computer set, cu, imbolizer and the transpoinder key? my car is 3.2 2003 Omega
Title: Re: where?
Post by: Elite Pete on 26 November 2008, 09:53:05
Hi Husam,
Whats the problem with your car?
Title: Re: where?
Post by: husam on 26 November 2008, 10:15:41
all of a suuden, starts but dose not move!
Title: Re: where?
Post by: Elite Pete on 26 November 2008, 10:19:05
Does the engine cut out and do you have any lights on, on the dash?
Title: Re: where?
Post by: husam on 26 November 2008, 10:34:12
engine is running well but no accelerationn!
maint. lights are on
Title: Re: where?
Post by: Elite Pete on 26 November 2008, 10:37:02
Do the Pedal Trick and post the results up ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687/1#1
Title: Re: where?
Post by: markey mark on 26 November 2008, 10:40:27
no way will you need a ecu matey ! more likely to be crank sensor  :y
Title: Re: where?
Post by: Marks DTM Calib on 26 November 2008, 10:42:43
More likely to be throttle body or pedal.....
The codes will reveal all
Title: Re: where?
Post by: husam on 26 November 2008, 10:52:45
if ecu set, where can I it buy from, any website?
Title: Re: where?
Post by: Elite Pete on 26 November 2008, 10:55:04
You won't need a new ECU ;)
Title: Re: where?
Post by: husam on 26 November 2008, 10:56:42
I do have the ecu out on my hands, looks brand new! how can I make sure it is damaged, frankly speaking I do not trust the Opel dealer here saudi at all !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Title: Re: where?
Post by: Elite Pete on 26 November 2008, 10:58:01
If you do the pedal test, that will tell you where the fault is
Title: Re: where?
Post by: husam on 26 November 2008, 10:59:42
hello elite, how sure you are
Title: Re: where?
Post by: husam on 26 November 2008, 11:01:38
how will the test show me the where fault is
Title: Re: where?
Post by: Elite Pete on 26 November 2008, 11:02:09
The pedal test costs nothing, takes a few minutes to do and will point you in the right direction as to the real fault.
Title: Re: where?
Post by: Elite Pete on 26 November 2008, 11:05:34
You have 2 options:
1, Spend hundreds on a new ECU and then come back when you have a car that still doesn't run, or
2 Do the pedal test, post the results up on here and take the advice. This option is free and Mr DTM is rarely wrong ;)
Title: Re: where?
Post by: Marks DTM Calib on 26 November 2008, 11:06:40
When a fault is detectd, the ECU stores an error code.
By reading the codes using the pedal trick we can get a better idea of the real fault and ensure you get the right part to solve your issue
Title: Re: where?
Post by: husam on 26 November 2008, 11:09:04
Thanks elite, I watched the vedio, did you mean that the fault will be shown as light or what?
Title: Re: where?
Post by: Elite Pete on 26 November 2008, 11:10:38
The light flashes out the fault codes. ;)
