Omega Help Area => Omega General Help => Topic started by: Proz on 01 December 2008, 08:34:07
Title: The last straw ??
Post by: Proz on 01 December 2008, 08:34:07
Hi all .... ive been having small niggly problems with this car lately and this morning the front ashtry has decided it doesnt want to close and seems to get stuck with about 1 cm left to go before it closes ..... this is not a big problem i know but with all i've had to do to this car its very nearly the last straw  >:( >:(  ... i couldnt see any way of removing it to try and repair it but i'll have a look at the maintenence section . Any tips on how it comes out and why i should not kick the sh** out this car greatly appreciated  :y
Title: Re: The last straw ??
Post by: dene wakefield lad on 01 December 2008, 08:39:03
open ashtray,screw in middle (top) and 1 either side :y
Post by: Proz on 01 December 2008, 08:53:09
Ok thanks i will have a look .... is it possible to repair or will it be broken and more new parts needed .
Post by: RichardH on 01 December 2008, 08:54:57
Often with the ashtrays, a piece of small black plastic has broken off which prevents it from closing properly.  Take it out and have a look inside and you might find it.
Post by: Proz on 01 December 2008, 09:28:56
Ok thank you .... it just seems to jam solid but i will see whats up when i take it out  :y
Post by: RichardH on 01 December 2008, 09:41:10
If it's just jamming solid, then make sure that it's set in it's runners correctly.  Had that probblem also on mine!
Post by: Proz on 01 December 2008, 09:45:28
It gets to within a cm of closing then stops ... seems to be the drivers side thats more jammed than passenger side.... did you need to remove it to fix it .
Post by: Proz on 01 December 2008, 09:47:27
I've decided im going to the boozer at lunch time with my brother and his pals so i wont be looking at it today .... will look tommorrow with that lovely hangover feeling  :D :D :D
Post by: RichardH on 01 December 2008, 11:14:20
Yep, I popped it out first.
Post by: Proz on 05 December 2008, 18:19:55
Thanks for the help ... took it out and all fixed again . :y :y
