Omega Help Area => Omega General Help => Topic started by: nick v6 on 05 December 2008, 18:33:53
Title: heater problems
Post by: nick v6 on 05 December 2008, 18:33:53
i noticed today for the first time
i had cold feet so i turned to dial for the hot air to blow to my feet and nothing happened
mine is a 94 2.5v6 cdx
the dial will turn to all the positions but only seems to blow out at the screen
ive got my dumb head on today hope u can all understand the problem i got with the heater
Title: Re: heater problems
Post by: TheBoy on 05 December 2008, 18:51:45
initially, check the vac layout in engine bay...
Post by: nick v6 on 05 December 2008, 18:55:06
where do i find that
ive noticed that when i start the car on the morning i here like an extra motor running and a slight hissing noise which only last about 20 seconds then stops
it seems to be coming from the n-s-f area of the car
Post by: TheBoy on 05 December 2008, 18:58:49
The noise is SAI and unrelated.  Check MDTM post in maint guides re vac layout under bonnet
Post by: nick v6 on 05 December 2008, 19:01:01
ok ill try and find it now
Post by: nick v6 on 05 December 2008, 23:59:12
wat is this
Post by: vauxfan2k on 06 December 2008, 00:18:38
I also have the same prob with my blower only working on the screen (95 model), I put it down to the vacum pipes being put on the wrong way when garage did my rocker covers and dis pack.
If i knew the correct layout i would fix mine also, but my other v6's are post 96 which had a different setup.
Post by: nick v6 on 06 December 2008, 06:18:56
the layout is on the site looks a bit complecated
mite have to print it off and study it
shame u dont live closer we could of put the cars side by side and sorted them both out
2 heads r better than 1
