Omega Help Area => Omega General Help => Topic started by: HGV mechanic on 14 December 2008, 18:48:38
Title: towing an auto?
Post by: HGV mechanic on 14 December 2008, 18:48:38
hi peps, is it safe to tow an auto without causing damage?
(only got to go 10 ml)
thanks ;D
Title: Re: towing an auto?
Post by: Lizzie_Zoom on 14 December 2008, 18:58:49
Yes up to 50mph in neutral.
Post by: tunnie on 14 December 2008, 18:59:58
no more than 20 miles i would say, its safest to disconnect to prop shaft.
And oh yes, fix that huge avatar!  >:(
Post by: JamesV6CDX on 14 December 2008, 19:01:37
Agreed - 50 seems a bit too quick as well :y
Post by: Dazzler on 14 December 2008, 19:01:46
I thought you couldn't go above 20mph with an auto :-/
Post by: Lizzie_Zoom on 14 December 2008, 19:03:12
Page 176 of the Omega Manual states:
"Vehicles with automatic transmission
should be towed facing forwards only and
must not be towed faster than 50 mph
(80 km/h) or further than 60 miles (100 km).
If the transmission is defective, or if the above
speed or distance is to be exceeded, the drive
shaft must be disconnected from the rear axle
or the rear axle raised off the ground. In the
latter case, secure the steering wheel to
maintain a straight-ahead position".
Post by: RobG on 14 December 2008, 19:09:20
"Vehicles with automatic transmission 3
Ah, but do you believe what VX say ;D ;D ;D
Post by: Lizzie_Zoom on 14 December 2008, 19:11:09
Yes, in this situation as they would have been liable for any damage caused to transmission systems if they had got this wrong, with a retraction being made that never transpired. ;)
Post by: JamesV6CDX on 14 December 2008, 19:12:02
Did they write this at the same time they initially declared a cambelt kit would last 80,000 miles?
Wouldn't chance it personally.
Post by: Lizzie_Zoom on 14 December 2008, 19:14:08
But they retracted that later and stated 40k, but the towing up to 50 still stands no-matter if I would do it or not. ;) ;)
Post by: JamesV6CDX on 14 December 2008, 19:16:33
Do bear in mind that cambelt kits are in constant use in every omega in the country, so if they hadn't changed the interval it would have been big trouble. - but in comparison, it's not very often someone tows one over that many miles at that speed - hence the damage does not occur so often.
I still personally don't think it sounds right. Especially when the prop takes a few mins to whip off!
I don't think the "if it was wrong they would have retracted it" opinion is all that valid in this case.... just my opinion though :y
Post by: vauxfan2k on 14 December 2008, 19:29:38
Personally I would take the prop off, its just not worth the hassle if something did go wrong, for something thats so easy to do there is no need to decide, the prop is gonna have to be disconnected to change the box anyways.
Post by: bobbertbear on 14 December 2008, 19:38:34
i always disconnect the prop at the diff when collecting auto's,and no need to tie it up as long as you take off the rubber doughnut thing
Post by: HGV mechanic on 14 December 2008, 19:55:22
ok cheers, surpose its best to disconnect prop, im just lazy lol :-[
oh and how do i sort the avatar thing??? ::)
Post by: MutantCav on 14 December 2008, 20:15:58
Reload the avatar link in your profile...will resize it...
Post by: Andy B on 14 December 2008, 22:10:46
If you're only going 10 miles be lazy and stay clean. You don't need to disconnect the prop to go such a short distance. My autos have been towed that far several times over the years.
Post by: HGV mechanic on 14 December 2008, 22:14:34
like the soud of that ,  ;)
Post by: TheBoy on 14 December 2008, 22:18:21
For 10m, just keep the speed down, eg max 40mph, should be OK :)
Post by: MutantCav on 14 December 2008, 22:19:07
Reality is there is a risk as no fluid being pumped round the TC/box...but there will be fluid in it anyway so take it easy and you shoudl be fine :)
Post by: Andy B on 14 December 2008, 22:28:31
Reality is there is a risk as no fluid being pumped round the TC/box... ....
 .... but for 10 miles? :-/   :y
Post by: MutantCav on 14 December 2008, 22:31:54
For 10 miles...why not just leave the engine of the car your towing running?? Then there is no risk and no damage...
Post by: Andy B on 14 December 2008, 23:04:32
It's just a guess ... but I bet that the car is a non runner, hence the reason for towing it in the first place. I may very well be wrong ... it's happened a couple of times ;) ........  ;)  ;)  ;)  ;) :y
Post by: HGV mechanic on 14 December 2008, 23:08:03
lol head gasket,  ;D ;D
thanks 4 all advise think i'll keep dry n risk it
