Omega Help Area => Omega General Help => Topic started by: Pitchfork on 16 December 2008, 19:38:23
Would drowning resulting in a Hydrolock damage a MAF?
I ask on the basis that from other posts they seem sensitive to abuse
If a MAF was faulty on a Traktor, what would be the likely effect?
Yes it would. Not so sure about effects on the tractor but on mine (2.0l) the car will have a tendency to stall, have some trouble starting and the idle will be all over the place.
iirc the tracktor wont rev cleanly if the maf is buggered try dissconecting it :y
Easy to check on trakker...
Unplug MAF, and use car for a day or so, plug back in and take for a drive. If its more responsive on pick-up with maf in, its working.
The difference is subtle, hence why you need to drive it for a while unplugged.
Notice, being gay BMW, it will NOT bring on EML due to MAF unplugged - BMWs rarely bring on EML, as that helps improved perceived reliability.
when my maf went the car would rev in neutral upto red line but in gear max 2000rev no power max 60mph
did unplugging it make the car perform almost normal again?
The maf does pretty much bugger all on this engine...
yes unplugged it, went normal left it unplugged until a got a reasonable price 2nd hand one
