Omega Help Area => Omega General Help => Topic started by: Richie London on 17 December 2008, 09:38:34
Title: could this be my HG
Post by: Richie London on 17 December 2008, 09:38:34
seems quite smokey lately, smokes all the time on idle, even when engine hot. but yesterday i was warming car up in car park for about 20 mins and when i pulled away i left a long trail of smoke. then it stopped as i was driving. losing a little water but not much, am i heading for a blown HG???
Title: Re: could this be my HG
Post by: Richie London on 17 December 2008, 10:50:42
no mayo on oil filler cap or in inside.
Post by: Kevin Wood on 17 December 2008, 11:14:02
Unlikely to be the head gasket, IMO. If it is indeed smoke and not steam (you will get lots of the latter in this weather) it would point more towards piston rings or valve stem seals, particularly the latter if it's smoky at startup.
Is it burning any oil?
Are there any signs of coolant leaks in the ususal places? (HBV and in the valley).
Is the coolant clean? Any signs of the reservoir cap venting steam? Is it running at normal temperature?
Post by: tunnie on 17 December 2008, 11:16:12
could be steam, after a 20 min drive to work, in the carpark mine was still pumping out steam.
Then again it was about -2!
Post by: Richie London on 17 December 2008, 11:26:59
doesnt seem to be any leaks, i put a litre of oil in about 5 weeks ago and no light come on at all, will check the coolant tank see if its oily too, temp is around 92.5 constant,
heater is blowing absolutely beautiful when its warm now. but my heated drivers seat has stopped working though for some reason
Post by: feeutfo on 17 December 2008, 11:36:28
white smoke/steam or blue grey oil smoke.
 Whats the oil like? Any mayo/emulsified appearance?  Pull a plug or 3 and check for water in the bore. Check where the water is leaking from(hbv, in the v of the engine and running down the back  of the bell housing, coolent transfer pipe above bell housing above or core plugs to head.) if its leaking in the bore and the smoke is steam then thats bad news. Wish you luck.
Post by: markey mark on 17 December 2008, 14:07:11
v6s do "steam" a lot from the exhaust when its cold ! just keep an eye on levels and condition of oil and make sure your antifreeze is up to spec ! very doubtfull its head gasket fella  :y
Post by: Richie London on 17 December 2008, 16:51:17
cheers, i do hope so m8,  would you believe my check oil level light came on earlier after saying this morning oil is okdoesnt seem as smokey today either and i cant see any elaks anywhere  ::) ::)i really cant afford anything at the moment as havent earnt no money for 5 weeks now. no money left for new car now either, solicitor still p'ing about with claim. and i want my new car :'( :'( :'(
