Omega Help Area => Omega General Help => Topic started by: parcelman on 21 December 2008, 20:45:42
after buying my omega yesterday ive discovered a few faults,door check strap nackered,no reverse lights,electric window switch snapped,and the milaege(odemetor)not working,got knows how many miles ive done.Are these easy jobs,and do any of you out there k now if i can check any of these problems apart from door check strap.
Reverse lights - presumably checked bulbs?
Window switch - replacement (2nd hand, usually fairly reliable)
odometer - does speedo work ok?
cheers for reply,yeh speedo works ok,could it poss a fuse
Most likely a failed - or tampered - speedo clock I think...
Replacing the entire instrument cluster only takes about 10mins.
There's a chap whole specliases in breaking Omegas near Heathrow and sells on ebay. He had 3 or 4 instrument clusters when I was there.
If you PM me I could dig out a phone number.
