Omega Help Area => Omega General Help => Topic started by: jamescropley on 24 December 2008, 11:53:03
My dashboard lights have gone out, i suspect a fuse but unfortunately i don't know which one it could be as i don't have the manual to check. Rather than pull every one out, can someone let me know which one it would be? Im hoping its the fuse and not the bulbs, a nightmare job i guess!
Thanks
here you go
www.omegaowners.com/forum/YaBB.pl?num=1161602008
Before you start pulling the dash apart just check the dimmer switch ;)
Ha, yeh i checked that lol. Maybe im being thick but i cant see which fuse it would be!
Right ive checked the fuse corresponding to which relay it should be
15-20A Reverse lamps, glove compartment lamp, automatic level control system, cruise control, seat and mirror adjustment, radio, heated rear seats, sun roof, instrument illumination, window operation, cooling fan, headlamp range adjustment
But....it seems to be fine. Anyone else have any ideas?
It's not a big issue but it means i cant see what speed im doing at night haha and with 6 points already, it's not good!
Thanks.
I found that sometimes the fuses vary so I'd just try a few others, worst case you have to put radio code back in.
I had a problem with interior lights and the fuse it was supposed to be was fine but just kept pulling fuses out till I found the right one.
Good luck!!
