Omega Help Area => Omega General Help => Topic started by: ngrainqey on 24 December 2008, 19:51:53
i thought the pipe for the hbv had popped off....
i looked to swap the hbv today....only there's no hbv
the heater bridge was going directly to the heater matrix and heater matrix to the coolant tranfer pipe and the bottom connector (on passenger side of the rear of the block)
i'm in the process of putting a hbv on buuut.. i cant see a vacuum pipe for it! ?
can anybody shed some light on it?
thanks
Do you have air con?
should be in rubber part were matrix pipes come threw the bulkhead alex :-?
nope no a/c
that pipe goes to a vac reservoir markey :-/
nope no a/c
no hbv then kid ! no a/c and no pipe coming out bulkhead no hbv ! have you got a spare hose at back of engine ???? :-? :-?
I could well be wrong, but I thought you only had a HBV if you had air con fitted?
couldnt see a spare one markey
i thought they all had hbv's to direct the hot water through the heater matrix to warm the air or otherwise direct the way straight round to the coolant transfer pipe
then dont worry about it then wont have one ! so have you found out were the pop came from ??? :-?
correct only fitted if got a/c or climate ! :y
nope not yet, i'll have to take the hbv out if i dont need it :P
looks like from the heater bridge or just below on the back of the engine, header tank is pretty much empty!
