Omega Help Area => Omega General Help => Topic started by: Ironingboard on 25 December 2008, 19:05:07
Title: What does this multiplug connect to?
Post by: Ironingboard on 25 December 2008, 19:05:07
Can someone tell me about a yellow multiplug I found. I took the cover off the front passenger seat side cover on floor that covers the seat runner and where the airbag and power seat connectors are.
Can anyone tell me what the connector is for, it only has 3 wires attached to it?
Title: Re: What does this multiplug connect to?
Post by: vauxfan2k on 25 December 2008, 22:07:51
yellow multi plugs are normally for the airbags, if it is disconnected then someone has disconnected the airbag in the seat for some reason, is your airbag light on?  if not it could be possible that it was disconnected to solve a fault in the system.
Post by: Ironingboard on 25 December 2008, 22:48:51
No this multiplug was taped up with original looking tape, nothing wrong with the airbag light or anything, I guess it must be something to do with a phone kit, but not sure.
Post by: omegadti on 25 December 2008, 22:54:20
I found this same plug on my CDX when I changed the seats.   I presume that it is for a seat occupied pressure pad for a seat belt
 warning light for a different market.   When I put elite seats in there was nowhere to plug it in to so I just left it taped up and all the functions of the seat still work.   For reference the airbag cable is the thicker yellow one on the bottom of the connection block.
Post by: Entwood on 25 December 2008, 23:11:47
Some cars/seats/airbag systems have a transducer in them which will automatically disable the passenger air bag if the correct type of child seat is fitted ......  could it be the wiring loom for this, on  a car that was not specced for the actual system ??
Post by: Marks DTM Calib on 26 December 2008, 10:33:49
Occupancy connector is a two wire two pin affair.
Post by: mickfit on 26 December 2008, 19:55:03
Hi mate
           Wod it have anything to do with the heated seator no heated seat???? no idea, just a thought ::) ::)
