Omega Help Area => Omega General Help => Topic started by: r1 on 20 December 2008, 23:36:56
Title: central locking not working
Post by: r1 on 20 December 2008, 23:36:56
hi central locking not working on a 95 omega,all locks work on key,replaced battery in fob and still no go so where next?
Title: Re: central locking not working
Post by: Radar on 20 December 2008, 23:38:58
could be the actuator
Post by: r1 on 20 December 2008, 23:54:24
is that in the door?
Post by: Radar on 21 December 2008, 00:01:50
yes- there have been a few posts recently about it - just type in door actuator or solenoid in the search and it should give more info
Post by: r1 on 21 December 2008, 00:06:03
ok thanks tried central locking not working in search and came up empty
Post by: r1 on 21 December 2008, 00:13:26
looked at threads and it seams there is a actuator in each door do
i have 2 change them all and what does one look like? and is the a way 2 test them?
Post by: markey mark on 21 December 2008, 00:40:23
you dont have to replace them all just the faulty ones ! best way to check is sit inside car and push down drivers door lock and see which ones go down ! then try from passenger door !  :y
Post by: r1 on 21 December 2008, 11:06:43
done as suggested and it only works on the drivers side door all three of the other doors dont work.just wondering as this is a base model if this has other actuators
Post by: Pete Elite on 21 December 2008, 15:05:44
  I would have thought even the base model has central locking :).
    Have you tried to see if the fuse that works the system has blown :question, just an idea :y.
Post by: r1 on 21 December 2008, 19:32:44
to be honest  i didnt check the fuse as i can lock it with the key,do u no what number fuse it is? thanks
Post by: hans solo on 21 December 2008, 22:44:12
Fuse no 20.....20amp.  :y
Post by: eddie on 21 December 2008, 23:20:06
Also check the battery carrier in the fob,mine had a broken connector to the circuit board,repaired it with a small length of thin wire and a bloody small soldering iron tip. To check its operation--does the red LED light up on the fob when you press a button?
eddie
Post by: r1 on 21 December 2008, 23:32:29
thanks will check
Post by: r1 on 21 December 2008, 23:37:18
eddie
yes the red light comes on when i press lock and the green light comes on when i press unlock
Post by: hans solo on 21 December 2008, 23:47:44
fuse 20 also runs..courtesy lamp, seat heating, rear window blind if you have one.  :y
Post by: r1 on 22 December 2008, 00:02:16
no rear blind or seat heating and the interior light works
Post by: hans solo on 22 December 2008, 00:05:18
fuse must be ok then. if you use the key in the drivers door, do any of the other locks work, ie open or close?.
Post by: r1 on 22 December 2008, 00:45:47
yes all locks lock on the key
Post by: markey mark on 22 December 2008, 02:38:08
drivers door soleniod then matey ! :y
Post by: r1 on 23 December 2008, 17:26:25
ok hopefull i can have a lok at christmas,i presume that the soleniod is next to the lock and must have some electric wires on it .since checking the fuse the other day  the interior light has now stopped working but the two map lights still work.the car has a mind of its own!!
Post by: Shagma on 28 December 2008, 23:38:48
is it not a main solenoid in the hidden side doors in the trunck? at least on my stationwagon...
Post by: r1 on 05 January 2009, 19:46:31
well ive had man flu over the holidays but checked yesterday the interior light and found a loose /worn wire,resolded it and interior light now works again thought i had solved proplem but still no t working. am going to get another battery for the fob as light doesnt look to bright and try again
