Omega Help Area => Omega General Help => Topic started by: ScottieMV6 on 15 January 2009, 19:15:38
Title: Oh break I've snapped a crank pulley bolt
Post by: ScottieMV6 on 15 January 2009, 19:15:38
As above. Putting crank pulley back on after changing cam belt, went to torque it up (65NM I think this is correct) and snapped one. Same in the water pump pulley!!!!! :'( :'( :'( :'( :'(
Assume I can't get away with 5 in the crank rather than 6? Will I be able to drill it out and re tap?
Title: Re: Oh break I've snapped a crank pulley bolt
Post by: ngrainqey on 15 January 2009, 19:24:09
if there's a stub sticking out on the crankshaft then you could possibly get some mole grips after taking the pulley off (depends how tight it is in the actual hole-might beable to get it out if it just tightens against the pulley)
tbh the crank pulley bolts i just do up very tight by hand without a torque wrench and have been fine without any sheered bolts or loose ones
Post by: Marks DTM Calib on 15 January 2009, 19:25:43
To tight....crank pulley bolts are 20Nm!
The water pump bolts are 8 with a dab of locktite!
Post by: vauxfan2k on 15 January 2009, 19:27:05
I never torque the pulley bolts either, just as tight as possible by hand. same goes for the water pump ones but with loctite, if you havent already I would be more concerned about gettin the water pump one out first.
dont like the chances of fitting a drill in there to drill them out tho..
Post by: ScottieMV6 on 15 January 2009, 19:27:58
Oh dear (putting it politely)!!!
I only did the water pump ones to 8 and still managed to snap one!
There is no stub sticking out on the crank so only thing I can think of is to drill it and re tap? Or will the metal be too hard to tap?
Think the water pump might be slightly easier as there is a bit sticking out of the back.
Post by: ScottieMV6 on 15 January 2009, 19:31:39
All in all its been a pretty disastrous first attempt at any serious work on the miggy.
Still got the cam cover gaskets and a service to do yet.
Its not put me off though. We learn from our mistakes.
Post by: TheBoy on 15 January 2009, 19:43:14
As said above, they are only 20Nm, which isn't that tight (certainly not 'do them up as tight as you can' :o)
Post by: Marks DTM Calib on 15 January 2009, 19:46:25
You shoudl be able to use a little chisel or flat blade screwdriver to tap the crank bolt remains in an anti clockwise direction to get it out
Post by: Darth Loo-knee on 15 January 2009, 19:50:39
Scot 8nm aint much above finger tight mate  :-[
Post by: feeutfo on 16 January 2009, 08:51:33
when i did my cam belt one of crank pulley bolts was already sheared. Vx service history. I took a scriber and gently "stabbed" the bolt/stud to one side of centre, move the scriber in an anti clockwise direction, like your stiring a cup of tea if you know what i mean, and it just undid. Wound it straight  out no problem at all. But depends how clean the thread is i guess. Hth
Post by: dbug on 17 January 2009, 15:47:57
These bolts are only small diameter (take a 10mm AF spanner if I remember right) and suprised you only sheared one tightening to 65Nm!!  However I should chuck your crank pulley bolts and replace with new as they will have been "stretched" by such a high torque and could well shear as a result in the future - a flying crank pulley will do a lot of damage.  Tighten to the correct torque - 20Nm - or tighten by hand using a suitable ring spanner!
Post by: ScottieMV6 on 19 January 2009, 13:34:09
Just been to Vx and new crank pulley bolts and water pump bolts are £2.73 retail inc VAT so ordered them.
Better to be safe than sorry!!! :y
