Omega Help Area => Omega General Help => Topic started by: Arrolman on 21 January 2009, 19:24:22
Title: TD breather hoses?
Post by: Arrolman on 21 January 2009, 19:24:22
Hi,
My omega is idling at just under 100rpm when I switch on in the morning, was just over 500rpm last week. Blocked breather hoses? Anyone like to point out where to check? Diagram maybe? :-/
Cheers,
Iain
Title: Re: TD breather hoses?
Post by: TheBoy on 21 January 2009, 19:25:54
Hi,
Cheers,
Iain
Idle increases as it warms up? Suspect CTS?
(Note: being a BMW engine, most failing or failed sensors do NOT bring on EML)
Post by: Arrolman on 21 January 2009, 19:28:19
Hi,
CTS? Idle doesn't increase, soon as throttle is moved it dips back to 500rpm
Iain
Post by: TheBoy on 21 January 2009, 19:29:43
Coolant temp sensor.  2 CTS on that beemer unit, both in head. One (the single wire one) is used for dash, other (2 wire) used by ECU
Post by: TheBoy on 21 January 2009, 19:30:23
If yours is paperclippable (about 50% of TDs are), iirc, cts is a 15
Post by: Arrolman on 21 January 2009, 19:32:15
Hi,
The stat is gone on it, nothing to do with that would it? Problem to repalce? Any need?
Iain
Post by: TheBoy on 21 January 2009, 19:33:33
Hi,
Iain
Stat is easy on TD, though unrelated to your idle
Post by: Omegatoy on 21 January 2009, 19:34:32
if stat is stuck open cts will never get to correct temp!!! :y
Post by: Arrolman on 21 January 2009, 19:39:06
Hi,
Might be the problem then, going to get done this weekend, after i've managed to get the fan off ::), and the rear discs and shocks done, and the steering idler ;D
Cheers,
Iain
Post by: Seth on 21 January 2009, 22:09:33
Don't forget - viscous fan is left-hand thread.
A sharp jolt usually starts it undoing.
