Omega Help Area => Omega General Help => Topic started by: spurno on 20 January 2009, 18:22:57
Title: demister problem
Post by: spurno on 20 January 2009, 18:22:57
hope someone can help with a problem that has just occurred.all of a sudden my demisters have stopped working and there is a lot of water on the floor behind the passeger seat.i'm certain that no water is coming in from sunroof or an open window.do any water pipes run in that vicinity?some airflow seems to come from the vents when recirculatory button is pressed.auto button doesn't seem to work now.any ideas appreciated.car is 2.6cdx estate 2001.
Title: Re: demister problem
Post by: vauxfan2k on 20 January 2009, 18:25:56
try looking in behind the scuttle, where the pollen filter is, You may find its clogged and the water is spilling thru the polen filter into the car. an easy fix  :y
Post by: hotel21 on 20 January 2009, 18:26:54
Sounds like the pollen filter drain is blocked.  Under bonnet, passenger side below windscreen, under the black plastic thing the wipers come out of.  Lift the flap, shine a torch down the hole and bet its full of water....
edit - must type faster...
Heres a link to a howtoo...    :y
http://www.omegaowners.com/forum/YaBB.pl?num=1206287560
Post by: spurno on 20 January 2009, 18:32:06
thanks lads,i know where that is,i'll try tomorrow and let you know.
Post by: spurno on 23 January 2009, 13:26:49
everything now ok.got all the fish out,there was that much water.all clear now,pollen filter changed,it was a funny black colour.jokes apart thanks to all,i can see where i'm going now and it's got the other half off my back as well.
