Omega Help Area => Omega General Help => Topic started by: vc009 on 24 January 2009, 18:36:22
Title: cambelt and engine management light
Post by: vc009 on 24 January 2009, 18:36:22
hi, I just had the cam belt and tensioner and the water pump changed on my omega 2.6 2002 auto lpg. For some reason the moment i switch the car on to gas it starts shivering or rough idling or hunting as its called sometimes and the engine management light comes on. This did not happen prior to me sending the car to the garage for the belt etc. the moment i switch it back to petrol it idles better but is still shivering slightly. the moment i drive it its perfect. It only shivers or idles slightly rough when in neutral or in park mode. According to the engine code it says misfire cylinder 1. all of this only happens around 500rpm basically when it is idling. the moment i rev it its fine. My mechanic reckons since the car runs on lpg the plugs are probably on their way out and i need a new set of plugs. is that true or iam i looking at some other expenditure
Any help would be appreciated thanks!
Title: Re: cambelt and engine management light
Post by: GastronomicKleptomaniac on 24 January 2009, 18:40:23
 Have a look for any missing vac pipes or splits, then have a check for oil in the plug wells *mumbles something about having been advised to do this on his own car*? Depends how mechanically confident you are... :y
Post by: vc009 on 24 January 2009, 18:58:21
thanks! il get them checked first thing Monday morning, is it ok to drive the car in the meantime or should i just leave it till then.
Post by: GastronomicKleptomaniac on 24 January 2009, 19:03:12
I'd leave it if at all possible... just in case.
Post by: vc009 on 24 January 2009, 19:15:10
ok, i think its a better idea to leave it..thanks again
Post by: JamesV6CDX on 24 January 2009, 19:16:47
Who did the cambelt - was it the proper cambelt kit, set up with the correct setting tools?
Post by: vc009 on 24 January 2009, 19:28:51
it was a garage here in cardiff, the parts were bought from vx dealership and yea he had the proper locking tools n things.
Post by: vc009 on 24 January 2009, 19:30:05
i just hope that iam not in for a big expenditure with this car, would it be something to do with the cambelt? because on acceleration the car is absolutely fine no issues
Post by: JamesV6CDX on 24 January 2009, 19:35:37
Just around the corner from me then - if you'd like a second look ;)
Are you sure he had the proper V6 specific kit, rather than a generic locking kit? :y
Post by: vc009 on 24 January 2009, 19:37:16
would appreciate a second look yea, where exactly are you?. Iam sure he had the specific kit since he does loads of omega's.
Post by: JamesV6CDX on 24 January 2009, 19:38:06
Near Riverside - where are you?
Post by: vc009 on 24 January 2009, 19:42:00
Iam in Riverside too, where exactly in riverside, what street
