Omega Help Area => Omega General Help => Topic started by: ScottieMV6 on 29 January 2009, 14:00:48
Just flushed heater matrix out - worked a treat, seem to have heat in car now. :y
However, I now have a new problem, coolant is now rising up the reservoir and overflowing out of the top (cap off).
Fix one problem and another appears!
That's what's supposed to happen! ;) It should be a closed system ie witha pressure cap on. Put the cap on and run it. :y
Ok :-[ Never seen that before but I will take your word for it and run it!
Cheers Andy. I will get your locking kit back to you now as well by the way! Anyday best for you? :y
:y It's the same reason you don't take the cap off a hot/running engine. You end up scalded. ;)
Any day is OK by me. SWMBO is off work next week & I'll be around over the weekend. :y
