Omega Help Area => Omega General Help => Topic started by: Martin_1962 on 04 February 2009, 14:31:26
Title: Noises
Post by: Martin_1962 on 04 February 2009, 14:31:26
What sort of noises do you get from the tensioner/waterpump ect?
There is a bit of a squeak and I am not sure if it is normal, due to the cold or something starting to fail.
Title: Re: Noises
Post by: Elite Pete on 04 February 2009, 15:28:40
Take the Auxiliary belt off and see if the noise stops ;)
Title: Re: Noises
Post by: cem_devecioglu on 04 February 2009, 17:22:07
some auxiliary belt tensioners are very prone to fault..
I changed 2 of them within 2 months before :-?
Title: Re: Noises
Post by: feeutfo on 04 February 2009, 17:34:02
 flip the seal out and grease the bearing, if no good the pulley can be bought from vx on its own without the tensioner, just undo the 15 mill nut on the arm, unless its lost tension of course.
