Omega Help Area => Omega General Help => Topic started by: RichB on 13 February 2009, 09:03:19
Hi guys I am going to change my rear pads today. I have got new pads, pins and retaining clip things from Vauxhall. Hopefully they are the right ones as there were two listed for vented and non vented. I got the non vented ones.
Anyway are the rear pads as easy to do as the fronts or is there anything extra I will have to do?
Cheers,
Richard
Its all covered in the rear brakes guide :y
Cheers Mark looked through but didn't think to check the rear brake servicing guide ::)
Any chance of you having a look at that coolant leak? I dropped you a couple of PM's. If your busy then no worries I will keep topping it up for a while longer.
Cheers,
Richard
Cheers,
Richard
Can probably have a look one evening next week.....weather has been a bit to poor to work on cars for the last few!
Tell me about it, only doing these today cause they are about down to the metal! Well I am available any evening Mark so whenever is good for you is good for me. I can bring you some more mince pies too if you want lol.
Cheers,
Richard
Hi, I've got the rear vented disc's on my beasty....... the pads are all the same, BUT the pins that come with the pads are too short for mine!
other that all that they are real easy to do!!
Nem.....
I hope I have got the right ones. I got the ones for solid disks, is this right for a 97 3.0 elite?
All the preface lift cars have solid discs at the back, vented are fitted to some later facelift cars.
