Omega Help Area => Omega General Help => Topic started by: markey mark on 11 February 2009, 10:43:19
Title: fault codes help please
Post by: markey mark on 11 February 2009, 10:43:19
just done paperclip test on mine after breaking down last nite and im getting codes
73 maf voltage
72 ????
31 no rpm signal
was expecting crank sensor but no ! just cut out coming up to a roundabout and would not go again any ideas on the 72 code  :(
Title: Re: fault codes help please
Post by: RobG on 11 February 2009, 12:08:37
73 maf voltage
72 ????
31 no rpm signal
72 Amplifier (Direct Ignition System (DIS)) control signal (A+B) Lead interruption, open circuit  :-?
Post by: Marks DTM Calib on 11 February 2009, 12:41:20
Totally failing crank sensor Mark......as opposed to one with a crap signal.
Normaly a bit intermittent as its often due to a wire break
Post by: markey mark on 11 February 2009, 13:23:34
have changed it mark still no joy  :( :(
Post by: markey mark on 12 February 2009, 12:35:40
right then just fitted brand new gen vx crank sensor and brand new vx battery still no go ???? could it be dispac ?? :( :( :'(
Post by: RobG on 12 February 2009, 12:39:23
Code 72 points that way :'(
Any spark at the plugs :question
Post by: markey mark on 12 February 2009, 12:42:18
thats me next check rob  :(
Post by: RobG on 12 February 2009, 12:45:12
Thought you would have done that before whacking another crank sensor on ;)
Post by: Marks DTM Calib on 12 February 2009, 12:46:42
72 is not a Motronic code.
Try disconnecting the MAF as a little test
Post by: markey mark on 12 February 2009, 12:53:02
right checked got spark will go dissconect maf now
Post by: markey mark on 12 February 2009, 12:56:49
no different mark all lights going just battery light staying on ??
Post by: Marks DTM Calib on 12 February 2009, 12:58:04
Ok, any vac leaks?
Does it start if you apply light throttle?
Post by: markey mark on 12 February 2009, 12:59:55
Ok, any vac leaks?
no but when towing home i jumped it off and it started but as soon as you take foot of pedal it dies deffo no vac leaks
Post by: Marks DTM Calib on 12 February 2009, 13:05:15
If it will run as described it does sudgest a possible vac leak or a sticking idle valve.
When it ran, was it lumpy or nice and smooth?
Post by: RobG on 12 February 2009, 13:06:32
Sorry, my mistake Code 72 relating to DIS is for the GM Multec ECU but I`m pretty sure on the Motronic 2.8.1 72 is the throttle switch not running on full load
Post by: Marks DTM Calib on 12 February 2009, 13:09:11
Nope, not a valid code at all for the V6 Motronic (and I just double checked the reference  :y)
Remember, there is no throttle swicth
Post by: markey mark on 12 February 2009, 13:12:49
yep smooth as allways but died straight away  :(
Post by: RobG on 12 February 2009, 13:19:13
Not doubting you Mark, but why would it throw a "72". Am I right in thinking that 72 might relate to "first generation 2.8.1" i.e. up to say MY 95/96 or am I just waffling :D
Post by: markey mark on 12 February 2009, 16:18:38
any more ideas chaps ???
Post by: markey mark on 13 February 2009, 10:05:22
so whats this code 72 ????
Post by: RobG on 13 February 2009, 10:30:21
AFAIK 72 relates to first generation Motronic 2.8.1 ECU
BOSCH Motronic ECU Fault Codes
This fault code chart shows the Bosch Motronic fault codes for the following systsms:- 1.5, 1.7, 1.8, 2.5, 2.7, 2.8, 2.8.1, 2.8.3, 3.1, MP3.1, 3.2, 4.1, 5.1, 5.1.1, First Generation and MPi.
72 Throttle Switch (TS) - full load contact High voltage - Full load switch not running
Post by: markey mark on 13 February 2009, 17:55:00
well mines a 99 mv6 3.0 so buggered on that then !  :(
