Omega Help Area => Omega General Help => Topic started by: b16 b3n on 25 February 2009, 09:50:57
Title: Passenger side airbag
Post by: b16 b3n on 25 February 2009, 09:50:57
Reeto, ive nealry done the whole hog to get the heater matrix out. The only thing in my way now is the passenger airbag.
Has anyone removed this? if so what od i need to do.
Im a mechanic so dont be afraid to hold back.
Or dont i need to reomeve this to take the dashboard completley out?
Thanks guys all help appreciated
Title: Re: Passenger side airbag
Post by: b16 b3n on 25 February 2009, 10:13:26
Ok then here goes ,
1, De-activate the air bag switch off all ign then disconnect the batt and WAIT for at least 60 sec for the system capacitor to discharge.
3, Remove the glove box.
4, Unclip the cover panal from the left hand facia end section.
5, Unclip the bulb holder from the rear of the air vent housing and position it to one side.
6, Slacken and withdraw the securing screws then detatch the nozzle from the left hand air vent.
7, Undo the securing screws and remove the left hand vent from the facia.
8, Unscrew the lower mounting screws and detatch the lower edge of the hinged air bag cover from the facia.
9, Using a long extentionbar and a pair of long nose pliers , slacken and withdraw the air bag cover hinge bolt.
10, Remove the hinged cover to expose the air bag.
slacken and remove the air bag unit securing bolts then withdraw the unit from its mounting bracket slightly.
11,Unplug the wiring connector from the airbag unit from the vehicle.
When handling the air bag allways have if facing up and away from you oh and do not drop it!
This information is from the haynes manual and before its discription has several warnings about handling,customising, and removing the srs system.
And you would do this at your own risk, I personaly wouldnt touch anything that could possibly jeapodise passenger safety, when 'baby' is at home and your out with your partner or friends their protection is gone. But hey thats my opinion.
I have worked with airbags before on many vehicles and can tell you that the last time someone who didnt treat it with respect accidently set it off and snapped his thumb off! He then had to have exstensive reconstuctive micro surgery to his right thumb which is still not right after several years.
this is another bit of thread i have found, does this sound right? im sure removing the lead connected to it deploys the unit?
Post by: TheBoy on 25 February 2009, 10:31:30
If you discon battery, and leave for a cup of tea (5mins or so), all SRS system components should go into a 'safe' (ish!) mode and not deploy when you mess about.  That said, still treat it all with respect!
Post by: b16 b3n on 25 February 2009, 10:38:14
cheers dude! I hate takin stering wheels off with airbags on, but actually taking the whole unit out is making me a tad shaky.
cheers matey
p.s if you dont hear from me ever again i probably aint got any hands left :y
Post by: Elite Pete on 25 February 2009, 12:33:38
I had a seatbelt tensioner go off which was bad enough ::)
